Hello there! First I'd like to start off by saying that this is my first instructable and any and all comments would be appreciated!
Are you a budding adventurer or an established one that can't find a mini that represents your character? Are you a DM looking for the perfect mini to represent that incredible boss monster you just came up with? Not a problem! Follow this guide and you'll be on your way to bringing your characters/monsters to life at a tiny scale!
I'm not a professional sculptor and I have no art training so this guide is written from experience and practice so there are probably better ways of doing many of the things I do in the guide, feel free to suggest them!
Step 1: Materials
There are many materials you can use to make miniatures, the most famous is the notoriously expensive "Green Stuff". I opt for the much less expensive sculpey which has many more uses than Green Stuff, but unfortunately makes a slightly more brittle mini so you'll need to be careful with them when you're using them. Anyways... on to the list!
-An Idea: This can be in the form of a written description by a player, your imagination, a drawing, etc.
-Super Sculpey: I use a combination of regular (beige) super sculpey and the firm (grey) variety. They'll each cost you about 20 bucks at a hobby shop so if you're on a very tight budget you may just want to use one of them. Each kind has its pros and cons. The regular kind is extremely soft and sticky when compared to its firm counterpart which can be great when making parts of a mini that are thin or added on later such as cloth, pouches, etc. On the other hand, it also has the problem that it is much more difficult to smoothe out at small scales. The grey kind is great because it's much more rigid while you're sculpting and can make sharp and smoothe edges with ease. Unfortunately it doesn't stick very well to the rest of your clay. Sometimes I even opt to mix the two clays together for an intermediate consistency, which may give you the best of both worlds in some cases or the issues of both depending on what you're making. On a side-note, You can make a lot of minis with a single block of super sculpey. I have yet to go through half a block and I've made nearly a dozen.
-Wire for armature: I use two different kinds of wire for minis that I simply happened to have on hand when I started making them. The first is a thick (1mm diameter) steel wire and the second is extremely easy to find "twist tie" wire. Every household has twist ties lying around, if you remove the plastic (or sometimes paper) layer around them, you have a handy and bendy wire!
-Pliers: Even if you're only using twist tie wire, two pairs of needlenose pliers make it much easier to bend the wire as you want it. Fingers are often too big for small bends for arms and legs.
-Sculpting tools: Because you'll be making something extremely small, regular sculpting tools aren't always the most functional. I've been told that dentistry tools are pretty useful, but I opted to make my own tool at a fraction of the cost. All you need is wood branch, a needle, a flattened out paper clip and some epoxy and tadaa! You have an excellent tool.
-An oven: I use a toaster oven to conserve energy. All it needs to do is go to 130 Celcius (275F) and be at least a few inches tall.
-Acrylic paint: The paint needs to be acrylic if you're painting super sculpey. Oil based paints will seep into the clay and make it even more brittle or even make it dissolve. Because I like to have a variety of colours I mainly use the primary colours and black and white and mix them to whatever colour I need at the time. I also have a few other paints on hand such as silver because it would be impossible to mix that.
-Small paintbrushes: You can buy a tiny paintbrush for a couple of dollars at most art stores. I bought a few different kinds to find out which kinds I prefer, So far the cheapest nylon brush I could find is the best for me.
-A flat, well-lit workspace: I use my desk and a fluorescent light. If you have an incandescent lightbulb, keep it far away from the clay. Because this project can take a lot of time, the lightbulb's heat can make your creation melt and sag so a fluorescent bulb (or if you're fancy an LED bulb) that generates little heat is optimal for use with polymer clay.
-Magnifying Glasses: I have tried a couple of different ways to magnify the minis as I make them. First I tried making an articulated stand for a dollar store magnifying glass, it's somewhat useful, but It'd need many more articulations to be perfect. Next I tried a magnifying headset. It's also somewhat useful, but kind of uncomfortable. These items can be useful for you to detect imperfections that are difficult to see with the naked eye.
-Time, patience and practice: I've made about 10-12 minis so far using the methods I'm about to describe and I feel that I learn something new with each one. They can be extremely time consuming to make at times or extremely fast to make depending on your level of inspiration, concentration and skill. My first mini took about 13 hours to make, but I am now able to make them in under 6 hours. My advice is to take your time and stop if you get frustrated. Skill takes practice to develop. I feel that I'm getting better at making minis, but that doesn't stop me from producing something sub-par every now and then.
(Optional) Sandpaper: More on this in step 6.
mharvey2 says: Jul 11, 2012. 10:30 PM
Loving this instructable! I have taken your advice and I am currently waiting on some Super Sculpey to arrive, but in the meantime I have been doing some practise pieces with cruddy dollar store, air-dry clay I had around. I am slowly better understanding the logistics to the armature and making the positions look right. I will post pictures of completed successes!
GreatAssGoblin (author) in reply to mharvey2Aug 23, 2012. 5:35 AM
Thanks for your comment, I look forward to seeing the results!
mharvey2 in reply to GreatAssGoblinAug 27, 2012. 9:43 PM
I've been working on making minis for all of the PCs of my current campaign - 6 of us! A big undertaking, hahah. So far I have 3 fully painted; 2 more are nearly done, and one is primed. They're bigger than standard minis since I felt I needed more to work with in terms of getting details right. Bigger than that, I have a mini I made of a Warhammer character for my brother's birthday. =] I've found this Instructable really helpful; thanks! I've also been looking into tutorials on painting techniques for minis that have been invaluable since painting my Avenger on the left there, hahah.
mharvey2 in reply to mharvey2Aug 27, 2012. 9:46 PM
Ack, didn't link the pictures in. Ohh well, Imageshack to the rescue!
http://imageshack.us/a/img818/7648/firsthalf2.jpg
http://imageshack.us/a/img255/8981/firsthalf3.jpg
http://imageshack.us/a/img812/6439/firsthalf4.jpg
http://imageshack.us/a/img811/4716/gotrek5.jpg
Periwinkle1 says: Aug 20, 2012. 5:28 PM
I really like what you're doing here. I was scratch building D&D models from DAS air drying clay in 1982. Crumbs 30 years and still doing similar things. At the time I couldn't afford the manufactured minis, so made my own. However, what I would say to you is... if you can possibly afford the best materials to work with, then you should get them. Your work is actually worth it. When you look at all the hours you've spent here, in planning, armature building, sculpting and writing the Instructible, and the entertainment value you've had from those hours... the actual cost of green stuff for the entertainment value per hour, is probably very small indeed. Great sets of dentist's tools (they're not real dentist's tools, they're steel copies of the stainless steel ones your dentist uses) are available on ebay for about £6 UKP, that's under $10 USD. And they'll still be good for use in 30 years time. Put them on your Christmas list in any case, along with a cheap pair of magnifying glasses (search ebay). I had a go at sculpting in green stuff a couple of years ago: http://www.lgtilley.co.uk/hind.htm
GreatAssGoblin (author) in reply to Periwinkle1Aug 23, 2012. 5:35 AM
Thanks for the kind words and for sharing your experience!
spiralbound says: Nov 26, 2010. 8:56 PM
You have a good thing going here, keep at it! From everything I've read, you'll eventually hit a ceiling with what sculpy can do, after which you'll need to switch to the green stuff. Apparently, if you want the best details in your minis, green stuff is the way to go. I personally don't know about this myself, but your instructable is very inspiring! I think I'll have to get some sculpy of my own!
GreatAssGoblin (author) in reply to spiralboundNov 26, 2010. 9:19 PM
Thanks for the comment! It's actually surprising how much you can do with sculpy. Since I posted this instructable I've gotten quite a bit better and am now able to do a lot more detailed work than previously! Practice really does help! So far the only limitation I've encountered with super sculpey is the brittleness. A few of my minis have suffered some damage when dropped a few times from a table. I expect that green stuff is probably a lot more resilient and maybe I'll give it a try if I have too much money lying around for some reason :P
Thrasym in reply to GreatAssGoblinNov 14, 2011. 4:24 AM
There is no real "upper limit" for details at this scale using polymer clays. Most of the Rackham Confrontation masters were done with it. The only real "limit" is that it needs to be baked.
spiralbound in reply to ThrasymNov 15, 2011. 6:58 AM
Yes, but I understood that sculpy softens a tiny bit as it heats up, removing fine details. Perhaps I'm wrong on this, but it's what I remember when I last used sculpy a very long time ago.
Thrasym in reply to spiralboundNov 15, 2011. 5:08 PM
Sorry, I know I'm late to the party, only found Instructables recently.
If you ever pick up the sculpey again, it certainly does soften up quite a bit but generally the details will not be lost or deformed. Depends on the "details" though, if it is a long thin unsupported nose or finger or strand of hair, for example, it might collapse...but that's one of the main reasons for the armature. Aside from complete collapse under its own weight, the details should remain intact.
Appollo64 says: Oct 19, 2010. 3:14 PM
These are awesome! Do know of any other types of clay that will work?
GreatAssGoblin (author) in reply to Appollo64Oct 19, 2010. 8:57 PM
I haven't tried any other clays for this application. A friend of mine tried to make minis using Fimo, but it apparently didn't turn out too great. Fimo also tends to expand when cooked which is an unwanted property when you work with small things with fine details.
"Green Stuff", a sort of expoxy compound, is supposed to be the best material for making modifications to miniatures and so presumably you could use it to make an entire mini, but it's quite expensive.
I think the most cost effective material for the result is super sculpey. Hope this helps!
Thrasym in reply to GreatAssGoblinNov 14, 2011. 5:01 AM
Greenstuff is a very popular putty but doesn't stand up to the hype with many of the more experienced users. As with all arts and crafts, your own knowledge, experience and desired end result will play a large part in how you get on with any medium. For example, greenstuff has lots of memory, making it good for organics, but bad for hard edges, weapons, electronics, etc. So, ya know, use what works for you and take all advice, mine included, with a grain of salt, most companies like to pretend they don't have any competition, but they do. ")
A friendly alternative (both in terms of cost and ease of use) is Magic Sculpt. I'd highly recommend anyone start with that. There's also ApoxieSculpt, ProSculpt, the list goes on and on.
If you already have greenstuff, you can try mixing it with a putty that is also probably locally available, called Milliput, to get something a little more user friendly, easy to use, only worth doing for the details, no use in bulking out an armature.
You can get most of these putties far cheaper, especially greenstuff, if you look online, consult local forums, etc. EBay is generally good at offering at least very close to the best price online for most hobby supplies. Just make sure to only send your money to a reputable dealer, as always.
lunius in reply to GreatAssGoblinDec 22, 2010. 10:36 AM
Green Stuff is VERY expensive for the quantity. Those of us who have been in Miniature Wargaming for a while learn that customizing minis is great, and Green Stuff is the best by far to do it with, but for about $20 for 2 sticks, which is enough to make maybe a single mini, then I decided to go to the modelling clay instead.
Another idea would be to make a single mini with your clay and then make a plaster mold of it. You can then make plaster sopies of your mini en mass (I did this with Warhammer 40K Tyranid Hormagaunts and got splendid results.)
desmondtheredx in reply to luniusJan 10, 2011. 1:05 AM
at miniwargaming they sell greenstuff for $17CA for a hundred grams
lunius in reply to desmondtheredxJan 10, 2011. 7:05 AM
yeah, but then they kill you on shipping.. It's nearly $15US to ship to me, plus whatever it costs..
GreatAssGoblin (author) in reply to luniusDec 22, 2010. 12:13 PM
Thanks for the comments Lunius. I definitely agree about the high cost of Green Stuff.
I've actually been looking into making molds of some of my minis and just pouring in resin to make plastic minis. From what I've heard and read, silicone is ideal for this sort of thing.
Plaster sounds like it would work too, but I don't know how well details will show. I've also never actually had to have more than a single copy of a mini before I started DMing and have been a little too busy to try it myself as of yet, but I'll definitely look into plaster though, sounds cheaper! Any tips on selecting a plaster for the job?
lunius in reply to GreatAssGoblinDec 22, 2010. 1:26 PM
go to youir local DIY store and tell one of the people there what you plan to use the plaster for and see if they can give you some good plaster and ideas..
njamspike says: Oct 20, 2011. 2:23 PM
this is a pdf about painting  rpg mini characters
flapper501 says: Aug 31, 2011. 5:30 PM
SUPER AWESOME
lacs98 says: May 15, 2011. 3:09 PM
Any way to do this fast?
gunman15 says: Dec 18, 2010. 9:50 AM
wat if u have no twistie ties
GreatAssGoblin (author) in reply to gunman15Dec 20, 2010. 8:29 PM
After a bit of experimentation with other wires, I can say that 20+ gauge wire that you can often buy in rolls at your local dollar store will do the trick, they're also easier to use than twist ties! Thanks for asking the question, I probably wouldn't have investigated this without your comment!
gunman15 in reply to GreatAssGoblinDec 24, 2010. 6:26 AM
no problem i was just asking
lunius in reply to GreatAssGoblinDec 22, 2010. 10:33 AM
or use small paperclips.. Office stores carry them for like $2 for 150.
daximos says: Dec 20, 2010. 6:39 PM
made one of these today, took a while to get it right but i was really happy with it.
great instructable, thank you
GreatAssGoblin (author) in reply to daximosDec 20, 2010. 8:29 PM
Glad to hear it went well! Thanks for commenting!
omegpirate says: Sep 4, 2010. 12:19 PM
Flaming sphere looks great. you have a great eye for flames
GreatAssGoblin (author) in reply to omegpirateOct 19, 2010. 8:53 PM
Thanks!
ChrysN says: Aug 24, 2010. 6:22 PM
That's great sculpting for someone without any training. I was thinking of trying my hand at something like this and I was wondering if you can do it without the armature or is that necessary, is it for support?
GreatAssGoblin (author) in reply to ChrysNAug 25, 2010. 6:27 AM
Thanks for the kind words! I've tried making a mini without the armature and I found that it sags, especially arms and legs because the pressure from the tool is enough to push the tiny limbs out of shape.
ChrysN in reply to GreatAssGoblinAug 25, 2010. 4:55 PM
Thanks, good to know.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
