Remove these ads by
Signing UpStep 1: What You Need
2. Pointed cone cutting tip (show below)
3. A hard surface to cut your disks on (like a tray)
4. Some practice disks
5. The real disks
6. A filtering mask (if you are ultra careful you won't want to breath in any plastic/aluminium dust from the disks)
7. A stencil (for the desired shape) and a marker
8. A steady arm/hand
9. Patience
Visit Our Store »
Go Pro Today »
Matthew
Digital Mayhem Screen Printing
matthew@digitalmayheminc.com
but what no one mentions, disks are sealed at the outer edge, if you did this the foil layer would have virtually nothing holding it on, in a 1 speed drive it may not do anything but if you put it in a modern 48 speed drive(or worse, 18 speed dvdrom) it would not only shatter from vibration, quite possibly destroying the drive beyond repair.... it would also rip the foil layer off the disk
now tell me, is it good to have a finely shreaded foil in your computer in any part?
goto http://www.powerlabs.org/cdexplode.htm if you dont believe me about the dangers....
oh and with dvds, they are built polycarbonate:foil:polycarbonate and are also sealed at the edge, if even a slight ammount of air and moisture gets to the foil they will stop working shortly because of disk rot
