My car uses an oil filter for which I have not been able to find a commercially made end cap oil filter wrench. Based on a forum for my make of car, others have the same problem. I need an end cap wrench because the oil filter peeks through a round hole in the splash pan under the engine. I made my own custom wrench. Some welding is necessary. (There are also
adjustable filter wrenches that fit various sizes of filter, but these have a limited contact area for gripping the filter.)
Materials:
1/8 inch steel about 3 1/2 x 3 1/2 inches
1/8 x 1/2 inch steel bar
1/8 inch rod
An old socket from a wrench set
An extra new or used oil filter to use as a pattern (No harm will be done to the oil filter in the process of making one of these end cap wrenches.)
Tools:
Hacksaw
Angle head grinder with a cutting wheel
Grinding wheel
"C" clamp
Vise
Screwdriver
Welder
I first made one of these filter wrenches when my wife got a 2002 Subaru Forester. The local auto parts store did not have an end cap wrench to fit the filter. I used a new filter from the dealer as a pattern to make an end cap wrench like the one shown in this Instructable. After buying a new Hyundai Sonata recently, I discovered the wrench required to remove the filter is the same as that required for my wife's Subaru. KIA and all four cylinder Hyundai engines use the same filter. I do not know which KIA models use this filter.
I thought I would use the FRAM filter specified to fit my car, but all after-market oil filters, even FRAM, have a rubber gasket that is just a little undersize, and those filters begin to leak sooner or later. After learning that, I decided to use only the factory filters. They are no more expensive at the dealer than a good after-market filter.
Cut the piece to look like a very rough gear, then bend the tines up?
Probably use a bit of heat at the corners, when bending to prevent cracking, but it should work ok.
Finally, it would have to be thick enough plate, so that the reinforcing top ring was unnecessary.
To avoid the need for welding on the socket... drill a 1/2" hole, then file it square.
Now you can stick the socket wrench right into the mating hole. :-)
With a little patience, it SHOULD be just about the same amount of work.
