3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Custom and cheap USB A plug
  • last photo ←
Note:
I know that this shouldn't be in the robot competition, I have tried to remove it but the FAQ pretty much say that the only thing I can do is sit it out.
How to make a USB A plug (the one that goes into the computer/hub) from a piece of veroboard, you can also use this method with you own etched PCB.
This is my very first instructable, so wish me good luck :)
I got the idea from a USB flash drive I saw, I thought it was quite novel.
Firstly lets get the boring/important bit out of the way:
Disclaimer
If you do not check you sizing and connections of every step you could possibly short out you motherboard/hub which can have disastrous effect (see picture of hard disk)
By constructing this instructable you hereby agree that any damaged caused by carelessness or faulty wiring is responsibility of the person who is constructing the device that causes the damage. I take no responsibility :)
The position and spacing of the veroboard strips is very important, you need to make sure it sits perfectly centre and doesn't short connections. Also keep in mind the sides of the USB socket will be ground connection.
Make sure you have the tools you need:
a sharp knife
A file
some veroboard
some bulking material (veroboard, copper clad, plastic, etc. something that is fileable)
soldering Iron
glue gun (and glue sticks) - Optional
super glue.
you should also have a pair of safety glasses too.
edit: I now realize that it was a mistake to put this in the robot contest, but I don't know how to remove it from the competition.
Step 1Preparing you pieces
To prepare you will need to file down your veroboard piece so it is slighly wider than the USB socket. do the same for your bulking piece (mine is a piece of copper clad board).
26 comments
Jun 9, 2010. 4:02 PMgb78 says:
I used to make these too, with some similar boards. Nice instructable, 5 stars.
Apr 5, 2009. 1:55 PMchilll2009 says:
Look awesome! I rated you 5 stars.
May 26, 2010. 5:25 AMchilll2009 says:
yeah, im a big fan of computer stuff
Jun 28, 2008. 5:05 PMGWJax says:
Very nice yet simple, But what are you going to do about an outter ground sheild devide for the internal post or will this not have that much effect on most MCU that are connected to it while programming them? Good Job!
Jul 18, 2008. 4:13 AMArtificial Intelligence says:
This is cool. I've used it to make a USB powered LEGO guy. Thanks to this instructable and to <a rel="nofollow" href="http://evilmadscientist.com/">Evil mad scientist labs</a> for the idea of <a rel="nofollow" href="http://www.evilmadscientist.com/article.php/LEDMinifigs">hacking LEDs into LEGO figures</a>.<br/>
Sep 10, 2008. 5:51 PMIW5 Industries says:
awsome!
Aug 23, 2008. 5:06 AMti112 says:
Could someone use this instructable to create another for making your own USB/flash/thumb drive or explain here?
Jul 10, 2008. 4:45 AMyourtubemeera says:
hello
does anybody has the circuit diagram of this robot
http://www.robotroom.com/Sandwich.html
i really wanna make this
n don hav money to buy d book or the PCB
Jul 18, 2008. 3:48 AMArtificial Intelligence says:
You can find a simpler and cheaper line follower schematic here. I've made 2 line following robots with this and I haven't experienced any problems so far.
May 18, 2008. 11:22 AMlittlechef37 says:
Leave it in the contest.... POOOOF ! (light bulb appears on littlechefs head....) I am making an instructable which I call THE RED BOX.... and this might be useful..... Good 'ible
May 25, 2008. 12:28 AMlittlechef37 says:
Oh you'll see.... I have yet to add Speakers to THE RED BOX....... and then I can deconstruct, then instruct while I recontruct.......
May 19, 2008. 6:32 PMoskay says:
This is very clever. I like it.
May 6, 2008. 4:54 AMp996911turbo says:
So obvious and yet I never even thought of it. Nice work!
May 4, 2008. 10:29 AMGorillazMiko says:
Sweet! I like the idea, it's great. Would this work (well, the board part) with 1up's The World's Smallest USB LED Light Instructable? Something like that. Nice job. +1 rating, but I don't think this should be in the Robot Contest...
May 5, 2008. 8:27 PMItsgoofytime says:
try to unpublish, then republish, but this time don't enter it in the competiton
May 5, 2008. 3:43 AMItsgoofytime says:
How would this be a robot? Robot's are not just a USB Plug.
May 5, 2008. 3:01 PMItsgoofytime says:
Robots are rare to use USB for direct communication. USB can be difficult for any hobbyist, unless you have a dedicated solution. Great idea though, just not in the robot competiton :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ratgod
