loading
Step 8: Correct Any Warping.
If you use an improper tool to cut your template (like I did) you may have warped the metal in the process. Flatten it between two pieces of scrap wood or anything flat and heavy.
I attached a phone cover with VELCRO having pressure sensitive tape on its back, then slip my phone into the holder when I drive. The VELCRO tape is available in any hardware store and can be cut with sissors to the size needed to fix the phone cover to a convenient place on the dashboard. I plan to remove the cover when I sell this car and attach it to my next car.
So you basically just jammed the metal into the gap between two interior parts? How is it holding up? I would expect it to work loose over time, unless perhaps you made a short, tight bend at the end to hook it over the back of the one of the trim pieces you pushed it between. I'm prepared to be instructed, though, as I need something similar.<br><br>A ready source for sheet metal to use on projects, is cases of various dead/outdated electronics. Fairly heavy gauge steel can be gotten from old PC cases, while lighter gauge stock comes from the tops of dead DVDs &amp; VCRs.
Nice<br> <br> L<br>
Nicely done. I have a handy nook already for my iPhone in my Tacoma, but there are some good ideas here. Thanks!
About This Instructable
16,174views
18favorites
License:
Bio: I am and artist/illustrator/custom picture framer/homeowner living and working in the San Francisco Bay Area.
More by Coliopteran:Custom phone/GPS car mount adapter
Add instructable to:
