Customize Your Home Poker Poker Table
3,809
7
Posted
Introduction: Customize Your Home Poker Poker Table
This Instructable covers the process making a custom graphic for your home poker table.
I made this one for my friends poker table.
I made it at TechShop. It is a really cool place, check it out: www.techshop.ws
Step 1: Creating the Vector File
In order to cut out a stencil on the laser cutter, you need a vector file. I used Adobe Illustrator.
Prepare the file like you do anything else for the laser cutter:
Choose whatever font you want, outline only with no fill and with stroke set to 0.001 for vector cutting.
Depending on what letters you use, you may need to modify your file to create tabs so the interior cavities of the letters remain in the correct position and don't fall out after cutting, the "b" shown in this photo is an example of what I am talking about.
Step 2: Choose Your Stencil Material and Cut to Size.
I chose to make the stencil out of cardboard because it was cheap and available. It worked but you may want to use a heavier poster board or something else instead.
The cardboard worked but I think something else would have probably worked a little bit better... Whatever you choose, just make sure it is safe to use on the laser and can handle a couple coats of spray paint without absorbing too much and letting the paint bleed through.
Cut the material to fit the bed of the laser cutter you are using.
Step 3: Cut the Stencil
Choose the appropriate vector cutting settings for your material of choice and run the file on the laser cutter, in a few minutes your stencil will be ready to go!
Step 4: Position the Stencil
Set the position of your stencil on the playing surface of your poker table as desired. And secure with a lot of blue painters tape.
Do your best to make sure that the bottom surface of the stencil is flush with the playing surface. I also used some thumb tacks in select areas to secure some tricky corners of the cardboard stencil that weren't flush with the playing surface.
Step 5: Cover Everything Else With Newspaper
Cover the poker table with newspaper everywhere except where the lettering will appear after spray painting.
Step 6: Paint!
With everything but the stencil covered in newspaper, spray paint over the stencil onto the surface one coat at a time as directed on the spray can.
I used a spray paint designed to work on fabric, here is a link on amazon
You may see a little bit of paint go through to make unwanted faint marks on the playing surface around the edge of the stencil like those shown in the photo. A damp cloth did a pretty good job of removing these with a bit of effort, I wouldn't count on it but it worked for me.
A big thanks for club xanadu for letting me alter the poker table!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
