Steps:
-Cutting Windows Out On Top
-Cutting The DVD Housing For Viewable Disk Spin
-Lighting The Interior With Your Choice Of Color
-Painting The Face Plate, Sides, and DVD Housing
VIDEO OF IT IN ACTION ON VERY LAST STEP
Remove these ads by
Signing UpStep 1: Tools & Supplies Needed
Torx Screw Drivers (You may be able to get away with just small flat head screw drivers intsead)
Small Phillips & Flat Head Screw Driver Set
Soldering Iron
Solder
Drill & Bits
Dremel w/Cutting Wheel
Hot Glue Gun
Wire Snips
Exacto Knife
Sanding Block (medium grit)
Sand Paper (medium grit)
Supplies Needed:
9 x 7 1/2" x 1/8" Sheet Of Plexiglass
6 LED's Of Your Choice
Black Spray Paint
30 AWG Wire
Masking Tape
Resistor (depends on what led setup you use)
Visit Our Store »
Go Pro Today »
Can you just ignore those or would I have to take those into consideration?
I've been measuring a bit and it seems that this modification doesn't have those holes anymore.
Could anybody help me with that?
any ideas would be much appriciated
the drive can get more dust than normal....
1. brick your console
2. burn your house down
3. electricute yourself
I suggest buying a ready made light unit from ebay called:
"Nexilux Smart LED Storm V2 for XBOX 360 Case Tunning".
It plugs into the disc drive socket on the main board with a splitter so you can plug your drive into the splitter.
Also there are a few useful features instead of just 1 colour thats comes on when you switch your console on and turns off when you turn the console off it has 7 diffrent colours to choose from with 3 diffrent settings on each colour.
You get a remote control with it too.
Also you can turn the lights off so you can game in the dark without led's glaring in your face.
How does it look without the LEDs? I'm going to do this project, but I'm not so good at wiring and the likes.
If you want more voltage you can wire into a constant 12V supply. There are many on the board. Reference here to find one <http://dwl.xbox-scene.com/tutorial/Xbox_360-HandC-V1_4.pdf>
is this still possible?
And you can get the strips as long as you want the guy said up to 4 meters not the your will ever need that for this project.
So i went in and bourght a 20 cm strip so i got 12 leds on the board and soldered it to the under side of the board where the power plug is with just two wire + and - and because the leds are on a board i just managed to glue them where i wanted
Here is a link to see what they look like and they come in blue, white, yellow, green and red
http://www.maplin.co.uk/Module.aspx?ModuleNo=218015
ebay for leds
i recomend this guy from hongkong
shipping took a week and a half
http://stores.ebay.com/hktaiyuen-LED-store
radioshack 500 resistor pack
if anyone needs help comment me or send me a email
momsgonnafindme@aol.com
i think the part where i had the most trouble was the painting of the center xbox 360 label in the middle. i tried covering it with blue tape and cutting it out with with exacto, which i did, but ending result was not coo, later i just ended up painting it by hand very meticulously with a toothpick, actually seemed a little easier than masking such fine areas. could you provide a more detailed explanation of how you were able to mask this area? did u just make it on photoshop then print it out and cut out the paper, then tape that on, and paint it? cuz that was my next idea, but if so, i guess you would have to stick the little O part on there too ay? =D
here is a link to my box i made
http://www.youtube.com/watch?v=ORhZInZxThc
GET A HARD DRIVE IT'S WORTH IT.
GET A BIG ONE TOO BECAUSE THE UPCOMING XBOX EXPERIENCE UPDATE WILL LET YOU LOAD ALL YOUR GAMES ONTO THE HARDDRIVE FOR FASTER LOAD TIMES AND QUIETER GAME PLAY, AND YOU WILL BE ABLE TO PLAY LOADS OF COMMUNITY GAMES. FULL GAMES.
It's on Major Nelson's blog
Zealous
Only one problem with your instructable. What if i want to power more LED's? say... about 30 of them. You can't do this from the fans power because it does not keep a constant 12V current running. Instead you can wire it into the power for the DVD drive with some soldering skill. My friend (slate.JUL) and I found this instructable very helpful. We will be posting a video of ours shortly.
http://www.radioshack.com/product/index.jsp?productId=2062313&cp=&sr=1&origkw=47+ohm+resistor&kw=47+ohm+resistor&parentPage=search
and I have these LEDs:
http://abctronics.com/Specification%203mm%20LED%20-%20BLUE%20html.htm
Haha well I've been experimenting lately with the LEDs and it seems to be happening to a lot of the resistors I use... That they get extremely hot(as in being able to melt tape) And i used 8 of the LEDs in a parallel
