Step 9Cutting Out The Windows In the Top of the Xbox 360
1. Decide what type of window you want and sketch it out on a piece of paper.
2. Once you are happy with what you sketched now you want to cut out the windows in the piece of paper
3. Trace the paper design on to the xbox 360 and make sure everything is straight and parallel like you want it.
4. Use a dremel with the cutting well on a low speed to cut about 1/8th of an inch away from your line.
5. Once you have cut out the window(s) take you sanding block and sand down you cuts until they are smooth and on the lines.
6. Next sand down your corners until they are also smooth and on the line.
comments
Add Comment
Add Comment
