3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Customized T-Shirts!
You have probably seen one of those methods to create your own patterns etc. on a T-Shirt. But the problem being, that it is time consuming and that you probably don't have all the materials and tools needed.
This method is easy and cheap, yet results a very pleasent result.
Step 1The transfers
The transfers
First of all you'll need your t-shirt to print on.
Also you will have to buy some 'T-Shirt Transfers' sheets sold in many stores, including your local printer shop. Often the 'T-Shirt Transfers' sheets will only allow you to use them on white T-Shirts, but it is possible to buy them for darker colors.
I found these at 3-4$ per sheet, but I live in a country where everything is expensive, so you might be ble to find them at a much lower cost.
40 comments
Dec 22, 2010. 7:58 PMquantumwarrior says:
Great tutorial! But on step four the amount of time you have to iron for each size didn't show up. It looked like this:
"...Ãý½ minutes for images smaller than 10x15 cm, 1-Ãý½ minutes for sizes around a half A4..."
Jul 12, 2010. 4:22 AMTututu says:
This is a very good instructables, i bought 10 sheets for 6€, and 2 tshirts for 7,50€, very cheap Here's the first tshirt I made! Thanks for this instructable
May 31, 2010. 12:59 PMYoungPyro19 says:
That's really cool I would like to do that, but aren't their laws on copyright?
Jun 5, 2010. 3:15 PMYoungPyro19 says:
Oh okay, I c... How do the shirts hold up in the washer. Does the design fade away quickly?
Jul 8, 2010. 3:54 PMYoungPyro19 says:
Okay, that's super. Thanks <=D
Feb 14, 2010. 6:55 AMclemens94 says:
 I make one for my Valentine and one for me with this picture.
They look like real tee !
My girlfriend is very enjoyed ! ;)
Dec 3, 2009. 10:36 AMliteoner says:
Did the same, but my t-shirt started to get rid of the design :(
Jun 16, 2009. 12:39 AMgameven says:
Hey i have recently seen this video of how to fold your T-shirts fast, just in seconds. I thought that you all would like to watch it.
[http://unlfreeculture.org/?p=160 Fold T-shirts Fast]
May 30, 2009. 10:04 PMLemonLily says:
I think the colour rubs off from beneath. Can you prevent it?
May 14, 2009. 4:41 PMLemonLily says:
You can take a picture of yourself, and put it on a shirt.
May 2, 2009. 1:53 PMBTrueK says:
You basically read the directions which came with the paper...
Mar 24, 2009. 12:40 PMSG1Oniell says:
I saw the metacafe thing backwards and thought it was cyrilic, my bad lol
Dec 15, 2008. 4:02 PMShampooRobot says:
what happens if you put one of those t-shirt sheets that only work on white shirts on a black one? like does it explode? exaporate? Not stick?
Dec 6, 2008. 8:13 AMwarrockdude says:
are they permanent?
Nov 8, 2008. 12:36 PMgatorfan94 says:
can you transfer to any color tshirt
Nov 4, 2008. 6:13 PMjeni-jeni says:
cool!
Oct 8, 2008. 5:34 PMprinter man says:
awsome instructable!! i use it alot
Jul 29, 2008. 8:23 AMmsgrafis says:
what is the paper you use to print? does the ink stay for long or just temporary?
Oct 1, 2008. 2:34 PMkiwi_soccer_maniac says:
Read step one..
Sep 7, 2008. 6:37 AMmoe8 says:
gr8 instructable i did a jackass one:D
Sep 6, 2008. 3:57 AMmoe8 says:
what option do u put in the printer settings ?
Feb 12, 2008. 7:01 PMschimmi says:
it's cooler if you do it yourself, with screenprinting
Jan 14, 2008. 6:25 AMkellimaier says:
Washing the T-shirt wrong side out and not drying it in the dryer will help the transfer stay in good condition.
Nov 9, 2007. 9:47 PMpetter633 says:
good instructable. are you sure you have to print them backwards, or is that just for transfer paper?
Jan 14, 2008. 6:23 AMkellimaier says:
You have to print them backwards. You are flipping the image when you iron it on.
Nov 13, 2007. 6:59 AMhappyasianguy says:
what kind of printer did you use?
Nov 9, 2007. 4:00 AMPetervG says:
(removed by author or community request)
Nov 11, 2007. 6:46 AMPetervG says:
What ever
Nov 10, 2007. 11:21 PMEvyllity says:
If you can find transfer paper that's for "dark colors," it's a lot more durable. I've had one shirt for better than five years with no chipping. Second, there's a feel you develop for ironing them on. i don't know how to explain it, but you know when you've really done it right. If you don't then it chips.
Nov 9, 2007. 12:52 PMTheCheese9921 says:
Yup, thats why I stencil with spray paint, for smaller outlines like the ego one my friend uses t shirt markers to outline the letters and for details.
Nov 9, 2007. 7:45 AMbadrang4 says:
YES THEY DO!
Nov 9, 2007. 7:33 AMsleeping_gecko says:
It may depend on size. I've used iron-ons twice. Once, it was with a small image (round, about 3-4" in diameter), and the second time, with an image that took nearly the entire sheet of paper. They were both transferred onto heavyweight white t-shirts. The smaller image is still on the t-shirt, wherever that shirt may be (in the back of a closet). I wore it very frequently for about 6 months or more. The other, full-page size image did start to deteriorate after a wash or two, and after 1 or 2 additional washes, it was in really bad condition. I don't know if that might be similar to your experiences, but it's what happened with mine. I'd recommend to use smaller images, or, if you're using a large image, try to cut it into sections (e.g. cut between large letters, etc,) if the background is clear/colorless. And pudi.dk, good Instructable. I agree with shooby that it's similar to package instructions, but the photo documentation of the process was well done. Bravo!
Nov 9, 2007. 7:40 AMmikedoth says:
Do you know if they have these for laser printers?
Nov 9, 2007. 12:49 PMBran says:
I believe they do, IIRC.
Nov 10, 2007. 9:31 PMgschoppe says:
they exist, but they're really hard to find in stores, and they don't even hold up as well as the inkjet ones.... in addition, they have trouble in some lasers.
Nov 9, 2007. 6:37 AMshooby says:
Well written instruct able, however it doesn't really provide any more information than what you'd see on the transfers package you bought.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:pudi.dk
