Customizing your school tie.
 by the casbah
Contest WinnerFeatured
Step 3: Iron, Draw and Cut
After de-stitching, you will find that there are a lot of fold creases in your tie, it will make your life easier if you were to iron out these fold creases.
Next you need to draw your template, (I recommend that you do this because I to start cutting straight away and I ended up with not enough material, luckily I had a few ties to play with) I folded the thin end of the tie and laid it over the wide end and drew round it because it was the perfect size.
Then you need to cut your tie.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
