Cut Bottle With Fire and String
12,078
246
14
Posted
Introduction: Cut Bottle With Fire and String
In this 'ible I will be showing you how to cut a glass bottle with fire and string. Now I am going to warn you, this project involves flammable liquids and fire, so be careful. I am not responsible for any harm that comes to you if you do not do this correctly. Now this is for people that do not have or have misplaced/broken a glass cutter, like me. If you have any comments, concerns, questions, etc. please say so in the comment section. Thanks, I hope you enjoy !!!
Step 1: Materials
- Acetone
- Glass Bottle
- Lighter
- String
- Scissors
- Napkin
- Tin foil (Optional)
- Bowl of Ice water (in some cases a large cup might work better)
- Sandpaper
Step 2: Preparation
This is where you start to get set up. If the title did not already give that away. If you are wishing to protect the labels on your bottle then wrap the bottle with the tin foil around the labels especially. If you do not wish to protect the labels then just peel them off and do not worry about the foil. First, get the string and wrap it around the base of the neck of the bottle, it works better if you wrap it around three times. Now get the acetone and the string. Fill the cap of the acetone bottle with acetone and soak the string in the fluid.
Step 3: Lighting/Dunking
Once you have soaked your string wrap it around the base of the neck of the bottle again and grab your lighter. Be careful on this part. Light the string, I have found that using a lighter that uses gas as fuel creates a stronger flame which will definitely make it easier for the entire string to light. Once the string has lit keep turning the bottle in your hands so that the string burns correctly. Once all the Acetone has burned off, dunk the entire bottle in water, especially the part with the string. You might hear a crunch, and the bottle will separate. You might have to apply a little force to get the two to separate. Don't get discouraged if it doesn't work the first time. Keep trying, it took me a couple of tries.
Step 4: Finish
Once the two pieces of bottle are separate, get the sand paper and sand away the rough edges at the cut. Once you are satisfied with the final product turn the bottle into anything you want, a cup, a candle holder, etc. I hope you have enjoyed this 'ible, if you have anything to say tell me in the comment section. If you have any criticism, then please make it constructive criticism, and tell me how to improve. Thanks, enjoy !!!
  • Gluten Free Challenge
  • Paper Contest 2018
    Paper Contest 2018
17 Comments
and this surely deserve my vote
this is amazing trick.
thanks for sharing.
No problem. I'm glad I could spread this to you guys, bhavik zure !
This was helpful, Thanks. I finally managed to cut 3 bottles
If you like this one then please vote for it in The Leftovers Challenge PilotOfTheFuture !
Hi - I understand that (real) wool works even better than string, although I've never done a comparison test. Might be worth a try? Good post, anyway!
I will definitely look into it and post the results. Thanks for the idea gillycol !!!
