Cut Nail Jerusalem Pectoral or Wall Cross
9,958
26
9
Published
Introduction: Cut Nail Jerusalem Pectoral or Wall Cross
About: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my first ...
Antique cut nails are still available and make beautiful religious art pieces when brazed. These things make nice gifts to pastors and other friends, as well as to enjoy yourself.
The Jerusalem cross has a rich symbolism and history. Its five crosses point to the five wounds of Christ. That reminds us He died to redeem the world. It also symbolizes the Gospel going out from Jerusalem to the four corners of the world. That reminds us of the commission Christ has given to His people. I like to think of it as who we are and what we are to do.
Cut nails are available through: www.tremontnail.com I used #6d common nails (not galvinized). They are 2 inches long.
Step 1: Prepare the Nails
Select 8 nails similar in appearance and without defects from your box of nails. Place them next to one another on a piece of brick. Use a MAPP gas torch or an oxy-acetylene torch or a carbon arc torch with an arc welder to heat the nails to red hot. Let them cool slowly in the air. They will need to be soft so you can cut and drill them later. The nails will have at least one sharp edge from the machine that cut them. Lightly grind away the sharphness.
Step 2: Lay Out the Main Cross
Place four nails end to end on top of a firebrick. Align them so they are 90 degrees apart. A piece of paper can help to get the corners square. Eyeball the layout from several directions and make minor corrections according to a pleasing appearance.
Step 3: Brazing the Main Cross
Use your torch to heat the nails so brazing rod will melt on the joint. Change the direction of the torch to guide the flow of the braze.
It is very easy to bump the nails out of alignment. Should that happen, heat the joint again and use a plier to position the piece that moved.
When slightly cooled, pull the main cross from the brick with a plier. Be careful. The brick and the nails are still hot enough to cause pain if touched. Set the main cross assembly aside.
Step 4: Cut Nails for the Smaller Crosses Assembly
Cut the head end from the remaining four nails. First put one in a vise and wrap a little masking tape around the nail. Measure 7/16 of an inch or 11 mm from the head and make a mark. Cut on this mark with a Dremel tool and a thin cut-off wheel. Keep each pair or pieces matched. Do not mix them with parts from other nails.
Remove the masking tape and grind away any burrs left by the cutting wheel.
Step 5: Begin Laying Out the Smaller Crosses
It is very easy to knock the smaller crosses out of alignment while brazing them. I have tried laying out all four nails and brazing the joints one after the other. The risk of knocking something out of alignment is higher that way. I now lay out one joint and braze it before laying out the second joint. The risk this way is that the first joint or two could be less than precise in their layout and the assembly will not look quite like you wanted it to look when finished.
Sometimes the braze does not want to flow as it should because of a coating on the nails. Here you can see that I touched the joint area of the nail pieces with a grindstone to expose bare metal.
After a joint has been brazed, some flux material will act as an adhesive to hold the piece in place on the brick. This helps reduce the chance something will be knocked out of alignment while brazing a later joint.
Step 6: More Laying Out the Smaller Crosses
Here the first joint has been layed out and brazed. The second joint is ready to braze. Even if everything is not in perfect alignment, it is not a problem. This is artwork, not precision machinery. Slight variations add to the visual appeal.
Step 7: Braze the Main Cross Over the Smaller Crosses
The flame on the MAPP gas torch does not show in the picture. Carefully position the main cross over the smaller crosses assembly. Look at it from several angles for the most visually appealing arrangement.
Sometimes the joint in the main cross has taken enough heat while brazing the main cross to the smaller crosses that the joint softens and a nail falls out of place. You can use extra nails like shims to add support at the outer ends. The best precaution is to be careful about the direction of the flame. Keep it on the joint you are brazing, but away from the center joint. Also watch out for stray heat directed toward the main cross joint when the flame bounces off of the brick.
Notice that the joint to the left has already been brazed. The same is true of the joint at the top. This photo shows the right side joint being brazed. The brazing rod will melt and flow when the metal is hot enough. Beware the temptation to push on the brazing rod to make it melt and flow faster. You only push things out of alignment.
Step 8: Brush Away the Slag
Use a wire brush wheel to remove the slag from both sides. Get into the corners as much as possible to remove the dry white streaks. Examine the joints, especially those on the smaller crosses. If braze did not penetrate the joints fully, a joint may be weak and a piece could break off with a little finger pressure. It is possible to braze a joint again, even at this point. The process may require adding braze material from the back side of the joint and then heating the same joint again with the assembly resting on the brick back side down. You want to have a finished product with the pieces in alignment and the braze looking as pretty as possible.
Step 9: Preparing the Cross for Use
If the cross is to be worn around the neck, as a pastor wears a pectoral cross, drill a 1/16 inch hole from the back side of the nail that is to be the top nail. Look carefully at the finished cross to determine which way it looks most appealing. Which side should be up? That will determine which nail to drill.
Drill at an angle so the loop for the cord is as high up on the top nail as possible.
I once made one of these for a woman who admired it. In her case, I mounted it to an 8 sided piece of finished walnut. I used four wire brads as stand-offs and very carefully brazed them to the back of the nails. That is a tricky thing to do because there is always the possibility braze material will flow around to the front side of the cross where there is not supposed to be any braze material. It worked, though.
Step 10: Attach a Wire Loop for the Cord
Get some suitable black cord at a fabric store. Start with 36 inches. Let the recipient shorten the cord by retying the knot and cutting it, if necessary.
Insert a wire brad 3/4 or 7/8 inch long from the back side. Lightly grind away any sharp edges on the point of the brad. Bend it around with a needle nose plier. Make the loop as smooth and round as possible.
Before attaching the neck cord, place the cross on some newspaper and spray lightly with an aerosol shellac to prevent rust. Do this several times from different angles, but only after the last coat has dried. Make a couple of applications from the back side, too.
These crosses are fairly simple to make, but they bring great wonderment and joy to those who receive them and see them for the first time.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    9 Comments
    Phil, you say "Its five crosses..." but I see nine crosses!
    Get a double 00 or a Triple 000 torch tip if you can! my double 00 works great
    I do not have an oxy-acetylene torch and my MAPP gas torch comes with two tips, but the smaller does not put out enough heat to melt the brazing rod on the nails. The larger tip barely does.
    Good job Phil. I'll point this one out to my wife. Her degree is in art, and she's done a good deal of jewelry making. This should be right up her alley!
    Your wife may have access to a better torch than I have. A small tip on an oxy-acetylene torch would be near ideal. She may also like to try some different sizes and styles of nails at Tremont Nail.
    SHe just uses my torches these days, but I'll probably buy her sone new gear in the spring. She has medical problems and really moves slow in the winter (even indoors). I'll probably get a new oxy rig, as my old stuff is inadequate. I'll make a point to get a real fine tip for her.
    Phil, Thank you for that information. I do take photos of some of my eggs in development because I teach, but I have not taught in several years due to my own health issues ( I have lupus) and I lost my mother and both inlaws and our last dog within 6 months so I backed off on teaching and writing intructions. I am rebuilding my teaching and will be teaching at some egg shows, so I will also post photos and instructables in the future. I had already visited your eyeglass repair with the monofilament. (I actually did that spontaneously for someone several years ago myself.) Good Luck with your projects. I hope you will also choose to vote for one of my eggs when the voting starts tomorrow. I primarily entered just because I love to show my eggs, but I would like to get some votes too. Carole B.
    Phil, I visited several of your Instructables and I found all of them fascinating. Since you had suggested this one, I read every step. I have seen Jerusalem crosses worn by clergy; do you make them as pins? I have a sister in law who is a youth minister, and this looks like a great gift idea. I hope to acutally develop some Instructable now. I only was directed here, because so many people know about my Faberge egg art,and they suggested I should enter multiple slide shows, so I did, but it has been major work over a period of a few days. Thanks for sending me to your site. I will continue to visit it. I am very interested in the filling the gap in the mitered corner also. Thanks again for visiting my slideshows as well. Carole B.
    Carol B. I have not made a Jerusalem cross as a pin to be worn on a shirt, blouse, or jacket. It might be possible to make one from horseshoe nails that could be worn as a pin or a broach. The horseshoe nails are smaller than the antique cut nails I have been using. But, the pieces would also be smaller and a little more difficult to handle during the making. The horseshoe nails might also work better if the sharp points were ground back to make a stubby square end at some of the joints. Thanks for your interest in some of my other Instructables. When I look at what I have posted I agree those things represent who I am. But, I also recognize there are lots of people whose eyes would roll back into their heads with boredom to hear even mention of some of those things. Eliminating the gap in a mitered corner is something a person can use in a variety of places. If you are involved in crafts, you will likely want to make your own frame sometime. Three of the corners always fit. It is the fourth corner that makes a problem. This Instructable takes care of the problem easily and simply. Instructables mean some work to develop. You can always leave one in progress and unfinished by leaving it unpublished until you are ready with it. Sometimes I take photos of my things, but sometimes it works out pretty well to make a drawing in MS Paint. See the Instructable I did on repairing the monofilament on an eyeglass frame. It would be interesting if you published how you did your eggs, especially those that are nearly free-standing ovals suspended in mid-air. Phil
