Cut Off Guide for a Circular Saw
Sometimes following a pencil line with a circular saw does not give the straight, smooth cut you want. For times such as those, a cut off guide is a great help. I was looking for a welding project and had some left over steel from another project. I decided to make my own saw guide.
The slotted brace on this circular saw is described in another Instructable I did. It makes home duty saws more accurate.
http://www.instructables.com/id/Too_Much_Flex_in_a_Circular_Saw_Base/
Step 1Materials
Materials
I used some 1/8 x 3/4 inch flat bar and some 1/2 inch angle iron.
13 comments
Dec 7, 2010. 1:06 PMaboelkasem says:
It's a good idea
if you please I well try it
Thank you
Aug 17, 2010. 8:02 AMFWFreitag says:
What is alot easier is to just use a speed square (a plastic one is about $3.00) with an attached piece of 1" x 2" x 12" long (or even longer if you want) with a threaded bolt through it and knob on the other side. You can slide the piece of wood up to the circular saw blade and then tighten down the knob to set the spacing. The wood is easily replaceable if you change saw blades or even saws. Too, you don't have the risk of cutting into metal with the circular saw. This is really similar to the Kreg "Square Cut" jig - but the plastic piece they use to set to the circular saw would be the 1" x 2" replaceable piece of wood.
Aug 19, 2010. 7:37 AMFWFreitag says:
I understand. Certainly your steel cross-cut guide would be strong - take the hard knocks of being used in the workshop or job site. I used a plastic 12 inch speed square and attached a piece of plywood to it for my cutting guide. It enables me to switch between my two circular saws very easily. It hasn't broken yet - but I'm counting the days! Using the piece of plywood allows my to set it directly/exactly to the line of where I'm cutting (or at least suppose to be cutting). I can even trim a little of it off to be exact. I could have used a steel speed square for durability. But your right - they cost about $15. I actually got the idea from watching the Kreg Square Cut Jig but didn't want to spend the money for it. Too, Bench Dog makes something similar. In reality, I think my idea is better than either of the Kreg or Bench Dog Pro Cut Circular Saw Guide because I can also set it to do 45's or whatever. I do have to take it apart to do such though and switch the bolt around. But theirs won't do that. Additionally, if I do that - I usually have to replace the piece of wood that I used to show the cut line. Too, I found that the only Speed Square that works well is the Swanson Speed Square because they have the "slots" built within to place your bolt to attach the piece of wood. Anyway, I liked your idea.
Mar 28, 2010. 1:46 PMkill-a-watt says:
I made one out of wood strips and coarse threaded sheet rock screws. I used the old 3-4-5 trick (6 inches by 8 by 10 , actually) to make it square.
Otherwise the tool is exactly the same.
I agree with you, if I were to make it out of angle iron, I'd likely clamp, drill, and then screw in a sheet metal screw. Then I'd test for squareness, and then I'd maybe practice my welding and then grind the excess screw off.
Feb 2, 2010. 8:28 PMCrucio says:
Do you have any experience with JB Weld (an epoxy especially for metals).  I wonder how that would hold up for this application.
Feb 2, 2009. 2:34 PMCaseyCase says:
I use a "speed square" for the same purpose.
Feb 3, 2009. 6:16 AMCaseyCase says:
Oh, don't get me wrong, you rock for making your own!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
407
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
