iImage Information
It is difficult to cut a straight line by hand with thin cut off wheel in an angle head grinder. I had an angle head grinder and wanted to make a mount for it to convert it to a cut off saw. I know you can buy a mount at Harbor Freight Tools, but I have a bias against most of their tools and wanted to make my own. I also have a welder. I used scraps of steel I already had.
Step 1Basic piece for a start
iImage Information
A friend gave me some scrap pieces of steel. One of these was a piece of 1 inch square tubing about 22 inches long with a 90 degree bend at one end. For a long time I had no idea how I would make use of this piece. If you choose to make a saw like mine, you probably will not have a piece like I had, but you can use other things. You could even weld a couple of pieces of square tubing together to make an "L" shaped piece.
I saw your design. I notice the grinder is held in place with only one bolt. It appears to me the grinder could twist on its mount and bind against the steel being cut. It also appears to me you have no fence to hold the steel from moving as it is being cut. My grinder is held very firmly in place and cannot twist or move in its mount.
My design is an adaptation of a design once sold by a tool company (Harbor Freight) in the USA. Thank you for your comments, but after about ten years of use, I do not see any safety problems with the unit I built.
Go ahead and curse me for wanting people safe from dangerous and improperly designed tool modifications. When your finger or hand gets cut off then you'll stop. This can throw a chip off the blade, loosen in the vice you made for it which is squeezing the motor chassis. Just as bad mixing electricity with water, mixing power tools with modifications FAR FROM THE INTENDED AND LICENSED SAFETY ORIGINAL DESIGN...
How would you feel Phil B if someone looked you up and told you that one of your improvised safety power tool modifications caused them to lose a limb? Or a life of a family member? Just looking at your skills and placement of the tool cutting blades lets me know you are not qualified to design and scary configurations of your contraptions are DANGEROUS!!!!!!!!!
Can you show us a way to put safety guards on your devices and a way to insure clamps at motor casings and switches can be operated properly as to the tools' original safety design? I don't want anyone hurt. Especially not you.
