3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cut a Royal Seal
Cut a Royal Seal
  • last photo ←
If you ever need to send a letter, adding a wax seal is the undoubtedly the best way to show class. Cutting a seal is a simple but laborious task, and the finished product is very rewarding. A seal made of the proper material will last generations.
Step 1Tools and Materials
Tools and Materials
Tools:
-metal lathe(optional, highly recommended)
-Dremel
-precision Dremel bits (small bits with coarse teeth)
-rat tail metal file
-vise
-400 grit sandpaper
-600 grit sandpaper
-jeweler's rouge(Flitz)
-printer
-Craftsman Bench Buffer(optional, makes things easier)
Materials:
-3" to 6" round aluminum stock, 1" diameter
-one sheet of paper
-glue(stick, Elmer's, whatever)
110 comments
1-40 of 110next »
Apr 29, 2011. 6:10 AMKyrc00 says:
As much as I appreciate the tutorial, somehow all the steps seem completely meaningless, minus doing the finish. Take a diamond wheel point dremel bit, like 5/64", and simply etch the design into the piece of metal before finishing it up. All it takes is a steady hand. I did a topography map on the back of my iPhone and people ask where I got the custom case. ;)
Not to say that I don't appreciate your efforts here, but for such a simple, I think the steps are far too over-complicated, turning a two-step process into eleven.
~Just Friendly Advice
Nov 3, 2011. 8:24 PMzappymax says:
and also instead of steel, you could perfectly use a bronze rod, much easier to etch any design. no problem with a seal on wax.
Jun 8, 2011. 4:54 PMcorradini says:
Quite a few thoughts/suggestions: (and, nice work, btw!)
1) Missing from your tool list is the Dremel attachment where you can set the depth. (But - 'spect for you using JB Weld, which is as essential as duct tape and WD-40 for any DIY'er!)
2) You spent (imho) disproportionate attention on polishing the opposite end (don't get me wrong -- it's a beauty!) - but the functional end is still fairly rough. Kind of a backwards priority. No insult - I do that ALL the time: spend way too much time/attention on the parts that don't matter as much - must be my ADD. ;-)
3) You didn't mention which Dremel bit(s) to use, other than 'coarse teeth'. I'd suggest something else (and I've been working on precision groove grinding for some time). You do NOT want to use diamond bits - they'll clog (aluminum is 'gummy'). I'd go with the HSS (high-speed steel), and almost certainly a ball-end (like their #107) -- it won't wander like a straight or point bit, especially if you use the SIDE rather than the end, and it's easier for the wax to release cleanly from a rounded channel.
4) You don't need a lathe or a buffer/grinder. The aluminum rod (I'd recommend getting 6061 aluminum, which is about the most common) should have square ends to begin with. (Try metalsupermarkets.com or one of their stores, or onlinemetals.com or mcmaster.com - or ANY metals supplier in your local area - they'll probably have cutoffs ('offcuts') of 1" dia 6061 and might even just give you what you need from their scrap bin - just ask nice and look poor.)
If you need to face a cut end, just use a flat fine-cut file (rub it with paraffin first to keep it from gumming up, and use a "file card" or just a wire 'toothbrush' (any hardware store) to keep it clean. I'm not sure why to bother with all the lathe work, OR use all that Al - when you're done engraving, just cut off an inch w/ a hacksaw (or better yet, a tablesaw - yes, you can cut Al w/ a standard carbide circular saw blade, and it'll be nice and square - just clamp it *securely* and use your miter guide (and eye protection!)). Then epoxy it onto a 3-4" long 1" dia walnut dowel, sand the wood to 400 grit or so (too fine a grit does NOT improve the finish of open-grain woods like walnut or oak!) and ease the edge on the other end a little with sandpaper. Then finish with something like MinWax wipe-on semi-gloss poly -- or just linseed or tung oil (let dry WELL between coats!) or even vegetable oil.
0000 steel wool and/or wet-dry automotive sandpaper (any car parts store) will give you an unreal mirror finish. If you really want to go to town, use toothpaste (moistened) and a cloth - seriously. You could polish the Hubble mirror with that.
5) The acid-etch suggestion is well-intentioned I'm sure, but a Bad Idea -- trust me on this one. (The details involved in masking, templating, etching, and a number of other issues - well, let me put it this way: your effort:results ratio will be VERY high, unless you REALLY know what you're doing, in which case you wouldn't be reading this. >;-)
Mar 14, 2011. 4:38 AMsypher says:
Awesome...
Would chemical etching yield better resuts?
Dec 29, 2010. 3:34 PMthepelton says:
Incidentally, I have been working on a roller seal instructable, but it takes a long time because I have to use the library computer, and can only get it for an hour a day.
Jan 14, 2011. 11:26 AMthepelton says:
It's done, now. I hope you have seen it.
Dec 30, 2010. 11:13 AMthepelton says:
Incidentally, remember to wear a mask while you are machining aluminum. It is slightly toxic, and it's better to not have to worry about it making you sick.
Dec 27, 2010. 3:43 PMthepelton says:
I have been carving wooden seals out of walnut. It is hard enough to stand up to pressing into wax, clay or dough, but not so hard it is difficult to carve, like yellowheart.
Dec 28, 2010. 4:24 PMthepelton says:
This roller seal was made out of Padauk, a bright red wood from the Andaman Islands that is about the same density as Walnut. The whole piece is about three inches(76.2mm) across, and about an inch and a half thick(38.1mm). It makes a figure that is about ten inches long in a soft material like sculpey or dough.
Dec 28, 2010. 4:33 PMthepelton says:
Ten inches, incidentally, is about 254mm. The whole idea was copied from roller seals used by the Mesopotamians about 3 thousand years ago. The picture repeats itself if you roll it far enough.
Dec 29, 2010. 3:31 PMthepelton says:
It took me a couple of hours to design and carve. The best wood I found was walnut (juglans cinerea). It is not too soft to deform when pressed into sculpey, and not so hard it's difficult to carve, like yellowheart.
Dec 29, 2010. 7:42 AMDr. Pepper says:
Great job!
Dec 15, 2010. 6:02 AMinertia18 says:
You can also use rubber to make a seal, like the use in the rubber stamps, much easier to carved and will also last longer. already tried it, just need to make and instructables for this... very busy this holidays
Dec 14, 2010. 6:49 PMuberrobodude says:
I've found that bolts work just as well, and is a lot easier to find. I hope this helps!
Dec 13, 2010. 5:57 AMmsoft4 says:
Pretty cool. I've always wanted to do this. Should I buy a certain wax or will just any candle suffice?
Now I can (finally) alert the queen of the unjust attitude of her cousin, Leopold, and the oncoming...
Dec 5, 2010. 4:04 PMbobwantzanapple says:
I was making a signet ring for a school project, and I finished it last night, I have never seen your instructable, but I also used a Dremel, and it came out pretty well, and I think it looks cleaner than yours when you use it. Unfortunately, I don't have any pictures of this.
Dec 5, 2010. 6:07 PMbobwantzanapple says:
I tried on the last post, I have no pictures of the wax
Dec 5, 2010. 7:19 PMbobwantzanapple says:
I was going to, but I don't want to steal your thunder.
Dec 6, 2010. 4:20 PMbobwantzanapple says:
Did you look through all of my comments after I made one on your instructable, and then call be a troll on the 9v thing, or was that a separate incident?
Dec 9, 2010. 12:09 PMGarlikguy says:
how skinny can these boxes get?
Dec 10, 2010. 9:15 AMGarlikguy says:
I can see the end!
Dec 10, 2010. 3:38 PMbobwantzanapple says:
How's the weather up there?
Dec 10, 2010. 5:16 PMbobwantzanapple says:
Let's see if we can get to the center of the Earth! I've heard it's nice and warm down there.
Dec 11, 2010. 10:05 AMGarlikguy says:
Wait, everyone stop. It's time for a dance break.
Dec 11, 2010. 12:28 PMGarlikguy says:
Dr. Horrible's sing along blog?
1-40 of 110next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:JamesRPatrick(Check out my blog!)
Currently pursuing a degree in Mechanical Engineering. contact: jamesrpatrick(at)yahoo.com
