Cut Off Your DSL Using a Fone Flasher!
3,947
4
5
Posted in TechnologyComputers
Introduction: Cut Off Your DSL Using a Fone Flasher!
A very simple instrucatble.
All you need is a DSL connection (wont work with dialup or cable from what I know) and this thing you can get at Radio Shack called the Fone Flasher. Basically you just plug it into a lamp and when a call comes it makes the lamp flash on and off. I got one for $1.50 at the clearance section.
Step 1: How To...
Just plug the jack into to a phone line anywhere in the house ,(You don't even have to plug it in to the power) and the dsl will be cut off. It happens because it doesn't have a dsl filter on it so it interferes with the connection and cuts it off. And best of all, all the cords to the modem are still attached so your siblings can't figure out why its not working! Have fun with it!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    5 Comments
    Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
    While this is fairly effective, it will not work in a situation where all lines are filtered at the NID ( like My setup)
                DSL Filter==Phones
    NID -<
                DSL Modem
    an effective way to cause a DSL dropout in this setup is to either, unplug and replug a phone line in the house about 5 times, or, using WIRED phone, use pulse dialing and just dial random numbers, just be careful to not dial 911. the best way is to dial your own number with the area code, and you will always get an error.
    Personal Rant(ignore this): &nbsp;s are a pain.
    Q: Can you connect this to the external phone switchbox on your house (between the line out to the phone wires and set it to flash mode so the DSL is blocked indefinitely?
    Oh, I had to read it a second time. So if the DSL is plugged in you can plug this in anywhere in the house and it will block it?
    As long as they are on the same line which, chances are, is true, then yes. It will block the DSL.
