Cute AA Voltmeter
Introduction: Cute AA Voltmeter
Ever wonder if those AA batteries are any good.  You could get out the voltmeter and check them.  That can be a hassle.  Sometimes it would be nice just to check them quickly.  In this instructable you will create a cute little AA voltmeter. By the way if soldering is not your thing, you can get the finished product from
Step 1:
Get the parts.  Here are some links and prices you can also order this as a finished product from
These parts are available from ebay for $7.44
$3.60 Blue voltage readout
$2.85   3XAA battery case with switch
$0.99 usb cable
Step 2:
Drill/Dremel  a hole for the usb cable.
Step 3:
Connect the usb cable to your laptop or usb power supply.  Using a voltmeter determine which cables are 5V and GND on the usb cable.
Step 4:
Connect the usb cable 5V to Red cable on tiny meter
Connect the usb cable GND to Black cable on tiny meter
Connect Blue cable on tiny meter to AA +
Connect AA - switch output to usb cable GND
Step 5:
Test out circuit.  Then solder and glue liberally.
If soldering is not your thing, you can also get this product from for $12.00 (free shipping in US).
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    1.2voltmeter which requiries 5v
    I created a version on Tindie that uses a built-in power supply:
    Now its more useful you should add its other uses
    Thanks for the comments!
    I created a new version that has its own power supply, available here:
    Great little device, but I am not sure having to find power for this would be any quicker than picking up a meter to do the test
