Cutting Board
22,302
330
9
Posted in WorkshopWoodworking
Introduction: Cutting Board
Making a cutting board is a very good way to up your skill in woodworking. The cool thing about it is that you can make them however you want, the design is totally up to you.
Step 1: Materials
You will need a few tools and supplies to make a cutting board.
•Wood glue
•Clamps
•Medium to light sandpaper/Orbital sander*
•Planer
•Stain*
•Router
•Miter saw
•Mineral oil
•And of course whatever wood you want. I used pine, which isn't a good choice for cutting boards since it is fairly soft.
Step 2: Prepping the Wood
I started out cutting each of my 1 X 3 boards around 23 inches. None of these cuts have to be exact. I then lightly sanded all four surface sides of each board.
Step 3: Glueing
When I put on the glue, I used a brush and made sure to remove any air bubbles. I spread the glue evenly on one piece and then laid another on top. I then clamped these two pieces together. While those pieces dried I sanded the others. I know you're supposed to clamp them all at once but I'm different.
Step 4: Accent Piece
Most cutting boards have an accent piece, one board that is different than the others. So I just used one of my pieces and ripped it in half on a table saw. Then I gave it two coats of red oak stain. The stain soaks into the wood so when I planed the top off the skinny piece is very defined.
Step 5: All the Pieces Glued
Step 6: Planing
Planing the cutting board is the easiest part of the whole process. A planer is a very useful tool to have around the shop. All I did was set the planer to shave off about 1/64 inch and made many passes until the it was all the same height
Step 7:
This is the part where the ends of the cutting board get shaved off. This is why I didn't worry about glueing the pieces perfectly flush.
Step 8: Sanding
Sand sand sand. And then sand some more. After the planing I used 150 grit sandpaper on a sanding block. I sanded the whole piece through and through. Then I used 220 grit sandpaper and sanded the whole thing. The 220 finishes it off and makes it super smooth.
Step 9: Handles
For the handles I just drew a box big enough for my hands to fit, then I got the router and cut it out. On the edge a got a round off bit and rounded the edges so it felt even smoother.
Step 10: Protecting It
Mineral oil is what I used to seal the cutting board, so no juices penetrate the wood, or the vegetables get any kind of wood taste in them. One coat of mineral oil each six hours, and put four or five coats.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    9 Comments
    I was going to mention about using hardwood and the use of Titebond III but I see others have already mentioned that. I started making cutting boars a couple months ago and use walnut, maple, cherry, white oak (red oak is too porous even though it is a hardwood) and purple heart as accents. The designs are limitless and beautiful! A couple other things I have learned: I use wax paper between the wood and clamps to keep the glue off of the clamps. I also clamp strips of wood above and below what will be my cutting board at each end perpendicular to the cutting board strips, this keeps my cutting board strips even and helps keep my boards from twisting when tightening the clamps. I learn something new on every board!
    I would suggest to use more like hardwood like cherry wook, oak but the best choice is mapple for his antibacterial specification. instead of soft wood(Soft wood will get railed by knive)
    And definitively to use titebond III
    And an extra tips the best way to put wood is the grain verticaly! Cause the wood is harder this way! But it's kinda harder to glue it straight
    Keep going great job!
    my next project... thanks for the step by step..
    Yea tkjtkj I didn't know, but thanks for telling me that. This was the first cutting board I've made.
    Nice lil project .. will give lots of aspiring woodworkers confidence, and a very useful product! < i like especially the 'handle' idea! Good!>
    I would seriously suggest, however, that you change the glue shown in your pics: TiteBond is a great glue but you show the lowest grade of it's three versions:
    TiteBond I , shown, is not waterproof. TiteBond II is 'sorta waterproof/water-resistant' but TiteBond III is WATER PROOF , and FOOD-grade! Harmless when used for products coming in contact with food.. :
    http://www.titebond.com/news_article/13-05-01/Understanding_the_Big_Three.aspx
    Thanks for the glue tip.
    I made some cutting boards recently and stained them by putting steel wool in vinegar, letting it sit for 2 days, then brushed black tea on the wood (the steel wool and vinegar solution reacts with the tannins in the wood and w the tea), and then brushed the steel wool/vinegar mixture. The darker you want it, the longer you need to let the steel wool/vinegar solution sit.
    Nice. I would try using TitebondIII next time. Normal Titebond will not last when you wash it, but TitebondIII will.
