3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cutting Christmas Ornaments With An Epilog Helix
I made it at TechShop.
As a novice user of the Epilog Helix Laser Engraver and Cutter, I decided to cut out some relatively simple stars and circles which will be used in a local elementary school for a Christmas art project. There were plenty of problems along the way, which I'm sharing so you can make different mistakes on your own version of the project.
For this instructable, I'm assuming that you've taken the Laser Cutting and Etching SBU class at TechShop or have equivalent knowledge if you're using a laser cutter elsewhere. This instructable only deals with cutting, and doesn't involve any etching.
The Epilog Helix uses a CO2 laser to cut and engrave non-metallic materials. Each laser cutting station at the TechShop is connected to a computer workstation where you'll load your design files.
Step 1Prepare The File
After deciding what to cut on the Epilog Helix, you need to create a drawing which lays out the shapes you want to produce. The TechShop recommends that you use CorelDraw to "print" to the Epilog Helix, so you should use a file format that CorelDraw can open. If you are going to work at the TechShop, prepare your file in advance and bring it on a flash drive. I used an open source CAD program called QCad to produce a dxf file, which is attached. Cutting many copies is straightforward, so I copied the original pattern to cover a 24" x 12" acrylic sheet.
1 comment
Nov 24, 2011. 6:03 PMPrix des Timbres says:
The way you just did. I’m really impressed that theres so much about this subject
Prix des Timbres
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:donprius
