loading
Step 2: Protegiendo la superficie (protecting the surface)
La soldadura de arco, al menos para mí, es una cosa muy sucia: todos los alrededores de la soldadura quedan salpicados de gotitas de hierro, que algunas veces se despegan fácilmente pero otras hay que sacarlos con la amoladora. Aprendí a protejer las roscas, los agujeros y demás partes cercanas a la soldadura, usando tiras de chapa de aluminio provenientes de envases de aerosol.
En este caso necesito proteger la superficie de la bolita, con excepción de las líneas de contacto con la varilla de hierro, donde irá la soldadura.
Arc welding, at least for me, is something very dirty: all around the weld are dotted with iron droplets, which sometimes come off easily but others need to be removed with the grinder. I learned to protect the threads, holes and other parts near the weld, using aluminum sheet strips from aerosol cans.
In this case I need to protect the surface of the ball, with the exception of the lines of contact with the iron rod, which will be welded.
Cool instructable, HAve you tried silver solder instead of welding? it might work better for the small parts<br>
Surely, but I don't dare... Never I did it, and I have not a teacher.
Nice use of scrap material's, considering your newly made forge, keep an eye out for spring steel. leaf springs coil springs etc they make some of the best chisel's i have used (for metal work though). and of course you are on the right track with using the barrings, perhaps you can use the Rase's (not sure on the spelling for that) of the barring's as well for some good high quality tool steel.<br><br>Keep up the innovative work.
Thanks for the comment, Anarx. Yes, some weeks ago I pick up from the waste a nice steel spring, it is waiting for transform into cutting tool.<br><br>I am doing an instructable about bearings cutting tool, today I must be something using them in the lathe for publish. Yes, I am using that you name rase's, I name them tracks but I don't know the correct English word.<br><br>
Very, very good idea, and the correct English word is; race. I might just make one of these even though I don't do wood turning
Thanks for the comment, and too for the correction. I will edit it as soon as possible. <br><br>Last saturday I made a very good &quot;cortafierro&quot; (iron cutter?) using the stem of a wasted car buffer (of suspension, stay system)
Oh no problem, and if you could post a picture of your iron cutter that would be nice. Now, from what I am visualizing, it seems like you made either what I call a &quot;cold cut&quot; or a &quot;hot cut&quot;, the cold cut is basically a cold chisel for metal and the hot cut is a tool for cutting hot metal. I think I might have a broken shock absorber (suspension buffer) laying around here, so I might make something out of it...thats if I can make a forge that is large enough
I added the chisel's photo in <a href="http://www.instructables.com/id/My-forge-mi-fragua/step13/Cortafierro-chisel/">Step 8 of My Forge</a>
Oh, thank you, that looks like it would be more of a cold chisel to me. If I remember right hot cuts have two edges, like a flat ground knife.
I think there is only one &quot;chisel&quot;. <a href="http://www.instructables.com/id/My-forge-mi-fragua/step13/Cortafierro-chisel/">You can see it here</a>.
muy buena idea, le diste temple? El de abajo tiene razon, usa tu forja para endezar una de las pistas del ruleman. Si no queres hacer una herramienta de corte, podes hacer un cuchillo.<br> <br> <strong>very good idea, do you temper it?<br> The one below is right, use your forge to straing one of the tracks of the bearing. If you do not want to make a cutting tool, you can make a knife.</strong>
A estas no las templ&eacute;, y lo de las pistas ya lo hice y <a href="http://www.instructables.com/id/Cutting-tools-2-herramientas-de-corte-2/">lo publiqu&eacute; ac&aacute;</a>. Gracias por el comentario.<br>
ah, buenisimo, lo hiciste rapidisimo. Por ahi puedan llegar a servir para tornear metal. saludos
Es probable, lo voy a intentar un d&iacute;a de estos.
Rimar, you can use broken bearing, straighten it in your forge and than sharpen. It is very good steel.
Thanks for the comment, jagr60, yesterday I did it. Today I will publish the instructable.
Great job! Gives me some other ideas. Thanks!
Thanks, Tom. I am doing a new instructable, maybe tomorrow I will publish it.
Wow! You went to a lot of work to achieve a hardened cutting edge. Can you buy hardening electrodes for an arc welder? They are used to put a hard surface on plow shares and build them up after they have been worn down by much use in the soil. With them you could cover mild steel with a few beads and grind them down to the shape you want for your cutter. It is just a thought.
Thanks, Phil!<br><br>I remember my father used that method, during 50's, but with oxyacetylene welding. The product was named Mil-Agro (milagro=miracle) and was really awesome. But after a seek last year, I can't find it nor any similar. <br><br>I asked at &quot;La Casa del Soldador&quot; (welder's house) and they sold me stainless steel electrodes. They are expensive, difficult to use, and I don't think are so hard as a ball bearing.<br><br>Today I feel a bit better, the day is sunny and mild, so I will try to launch my forge to straighten a broken ball bearing. Then I will post the result, obviously.<br><br>By now you've realized that my motivation is not doing something technically right, or most convenient, but just experiment and have fun. Otherwise, it would have been better to go to La Plata and buy two or three good cutting tools, they aren't so expensive.<br><br>
Hope your health continues to improve. Yes, we do all this stuff for fun. And for what we learn along the way. There is no teacher like experience. I for one truly appreciate you sharing your experiences.
Thanks, SharpyWarpy. I hope may sleep al least 5 hours that night. I am doing a new instructable right now.
a lot of work but the reward comes in satisfaction every time you use the tool you made
Thanks, I8nite!<br><br>Well, maybe can seem a lot of work, but really went 2 hours of light work: to cut a piece of iron bar, to do a hole, some hammering, a tiny welding (the only delicate part) another cut, and then seat the edge.
No te cansas de hacer cosas grosas, segu&iacute; as&iacute;. Saludos
Gracias Bruno, fijate lo que le contest&eacute; a Phil B. Un abrazo.
About This Instructable
12,013views
23favorites
License:
Bio: I am leaving Instructables, soon. I am very upset with the turnaround that has the page to post the manufacture of a dildo. Me llamo ... More »
More by rimar2000:Calculating a pulleys based speed drive (Variador de velocidad a poleas) Aerostato (hot air balloon) Easy monopod (Monópode fácil)
Add instructable to:
