If you don't mind performing a little surgery, you can fold the box spring in half, making it much easier to move around. After rebuilding it, the box spring will still have all the structural integrity and support that it started out with. Here's what you'll need:
- flathead screwdriver
- Pliers
- Scissors
- Wood Saw
- Rope, cord, or twine
- Power drill/screwdriver
- Wood screws
- Some lumber that's the same thickness as your box spring's wood; 1x2's are probably good. You need enough to make four boards that span the four central crosspieces.
- Staple gun or upholstery tacks and a hammer
Remove these ads by
Signing UpStep 1Remove the staples on the long sides
Once you're done, the fabric shouldn't be attached to the wood frame at all on both long sides.
What, Americans are so wimpy that one mattress isn't good enough? :-P
I used a screwdriver and pliers to remove the cover underneath. Then used a jigsaw to cut the 3 wood supports. I used Thule load straps to bend the mattress over backwards and it held just fine as we brought it upstairs. I used your idea of the metal plates, but I drilled holes and used bolts/nuts/washers instead of screws for added strength.
We recently moved into a really old house, and the queen size boxspring would not go up the stairs. We have been sleeping on the mattress on the floor for 2 weeks trying to figure out what to do.
