Such large tiles have to be precision-cut for installation, which is hard to do without professional, large, expensive tile saws. This instructable shows how to cut these tiles using a tiny hobby diamond saw.
Remove these ads by
Signing UpStep 1My tiny hobby diamond saw
First problem is that the tiles are much larger than the table; I fixed it by laying a piece of plywood with a slot for the diamond blade. I plunge-cut the slot with a circular saw, and attached the plywood by driving drywall screws from the top, through some holes in the tile saw's table into a piece of lumber underneath.
The second, more serious problem is that it's hard to make long, straight cuts with this setup. The diamond blade is very unforgiving of side loads, and will bind unless the cut is very straight. It's practically impossible to feed the tile by hand into this saw in a straight line, so even if the tiny electric motor didn't stall the cut would be ragged. This instructable explains how to set up guides for perfect cuts.
Stone countertops are really heavy so you generally don't want to be moving them when you are cutting them. Your best bet is to move the tool that's doing the cutting. The professional granite/stone installers that I've seen use a normal circular saw with a diamond blade to make long straight cuts on countertops and an angle grinder if they need to do something a bit smaller (e.g. cutting out an opening for an outlet or light switch). If you don't feel you can do a straight enough cut freehand then you can carefully clamp a straight edge of some sort to the material and then use that as a guide to keep your cut straight.
Furthermore, if you're looking to do something like this as a one time DIY project, it'll be cheaper to buy a couple of 7" diamond blades for your circular saw than buying a wet tile saw.
I do agree that the best (and cheapest) way to cut these tiles would be a circ saw and a straight edge - although one blade is easily enough to cut a whole kitchen. You can get a 7" DeWalt diamond blade at HD or Lowe's but I would recommend getting a blade with a higher tooth count from a granite fabricators supply shop.
Also, using water will yield a cleaner cut ,longer blade life, and a lot less dust but its not 100% necessary. We usually use a large wet sponge to apply the water. If you do use water make sure your saw is plugged into a GFCI outlet though.
I mentioned a couple of blades because in my experience it's not hard for someone who is inexperienced to burn through one while they're learning. It's not hard to get the hang of it, but I've found that having a brand new blade that you can jump to makes people less likely to try to finish with a blade that's a worn out.
I agree that using water will yield a better cut, but I'd be a little reluctant to suggest it given the potential dangers associated with working with water and a power tool (particularly one that's not meant for use in a wet location). In my experience if you factor in side and back splashes you can get good cut even without water. Although perhaps the thing to do would be suggest both options and let folks do a few test cuts dry vs wet and see what cutting method will work better for their project.
