Cutting Sheet Metal on the Water Jet
Introduction: Cutting Sheet Metal on the Water Jet
I made it at TechShop! Find them at
Step 1: Import Dxf File
Import your dxf file into Flopath
Step 2: Move Part and Select Cut Paths
Move your part where you want it to be on the cutting bed, select lines to cut, select speed.
Step 3: Duplicate for Multiple Parts
Duplicate this for more than 1 item to be cut from a sheet.
Step 4: Auto Path It
Use auto path to create all the cutting and traverse paths
Step 5: Export
Export path as... To create the ORD file for Flocut.
Step 6: Load File Into Flocut
Load file, select material.
Step 7: Position Material
Square it up on the bed also
Step 8: Set Temporary 0,0
Align head to corner of material and set 0,0
Step 9: Dry Run
Dry run no pump or water or abrasive.
Step 10: Set to Auto and Run
Set pump, water, and abrasive to auto and run!
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    I would advise to learn how to path the parts properly. I am a water jet operator and I have seen so many people crash the machine or break nozzles due to auto path. If you can, learn to manually path the parts. It will save a lot of stress.
