Cutting Slots in Tubes
2,839
4
Posted
Introduction: Cutting Slots in Tubes
I had to cut slots in a tube with a router , which is a real good way of having your hand chewed to the elbow ... I needed a holder that would hold a tube parallel to the direction of movement , that wouldn't allow it to rotate or shoot off the table @ 100mph . So all it has to do is :
• hold a cylinder
• be non-slip
• protect your hands
• allow you to see  what’s happening
• be cheap
• be simple
Yeah that looks like a lot trouble ….But there is a vacuum form machine @ the TechShop , so I made it at the tech shop. All I needed was a form … I had some leftovers, some 2"x4"  , a piece of PVC pipe and a board from the trash … ok I added some screws and holes , lots of holes …….
Step 1:
I built this in an hour …..  for spacing I dropped a 2X4 piece between the tube and the back support so the tube (I used ¾”pvc ) will be parallel to the back … no measuring required. BTW just to stop the vacuum from drawing into the tube ( pow)  I stuck in some cutoff pieces and a silicon plug …..
Step 2:
Off to the vacuum form machine ……
Ok I spent money here …. I got an oversized piece of PETG so the cutoffs can be used as stiffeners then some adhesive sandpaper.…
For those the TechShopies.. I used a little extra heat so the draw would be easy and leave the ribs if you don’t get ribs from your draw , drop in some of the extra plastic in between the back and tube … see pix
Step 3:
Step 4:
Then you grab some of the adhesive sand paper cut into strips  …. Stick to the inside walls of the tube area and you have a holder …..The back was a little thin so I used part of my cutoffs in the back support …
FYI when I used it I was cutting PVC pipe and after a couple tries I found you just need to go slow and use a slide guide …
A board clamped to the router  table works too ,have fun ….try it at : www.techshop.ws/
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
