Introduction: Cuztomize Your USB/Flashdrive
When you buy a USB, don't you think others has the same? If so, try to personalize it with this instructable!
Step 1: Take Out the Flashdrive
If your Flashdrive has a rubber casing, pull it off. If it has a hard case, squeeze the casing with pliers until there is a hole on top.
Step 2: Styrofoam
The USB should look like this. Take your styrofoam.
Step 3: Measuring
Measure your desired size or shape as long as the USB fits in it. Make also for a cover. Just make sure you cut it neatly.
Step 4: Scrape
Using a small knife or a sharp stick, scrape a deep hole in the foam. Make sure to fit the USB constantly to get the exact deepness, width and height. Do the same with the cover.
Step 5: Transfer
Place the USB in.
NOTE: Wrap a layer of masking tape on the body and the bottom. Don't cover the part you'll plug.
Step 6: Personalize
Personalize it! Place construction papers around it. Paint it. Color it! Do anything with it! THERE! Your new USB.
Interesting!
