Cyborg Helmet
225
6
Posted
Introduction: Cyborg Helmet
Extraterrestrial Cyborg Helmet
- Rawlings Baseball Helmet
- Computer Tower Case Side Panel
- Metal Washers
- PVC Hose
-PVC Gears
-Metal Gears
- Gorilla Tape
- Hand Saw
- 50 Strand LED Fairy Lights
- Industrial Strength Velcro
- Dremel Tool
- Power Drill
- Multi-Grip Adhesive
- Metallic Copper, and Silver Spray Paint
- Black Spray Paint
- Rubber Hose
- Green Acrylic Paint
- Track of Hair For Weaving
I began by cutting the brim off the helmet with a hand saw then filing down with a dremel tool. Next I carefully removed all padding from inside and drilled 50 holes at random from the outside. I continued by adding the Velcro on the inside back of helmet bottom center this is where the battery pack of the LED lights will be added. Then I spray painted the Helmet Black and distressed it with silver and copper metallic paint in a stroking motion with a rag from an old Tee-Shirt. I then began stringing the lights throughout until all holes had a light flashing and secured with a piece of Gorilla tape making sure to cover the wires also with the tape. After that I glued the cushions back inside using Multi-Grip glue, added Velcro to the battery pack and attached to the one inside. Next I mixed green acrylic paint with a small amount of water making a wash poured into the PVC hose tube giving it a green like Antifreeze color. I continued by attaching the PVC hose from left to right, ear to ear around the back of the Helmet securing in place through other holes drilled using screws and washers. I distressed the side panels of the computer case using a stroke motion with silver spray paint and attached to the sides of helmet using screws and washers over the PVC hose on left and right sides. I then measured and cut down the center a red rubber hose and glued to the perimeter of the helmet. Distressed again with metallic silver spray paint with a stroke motion using a rag with silver spray paint. Next I attached an Asian style Finniel on top of helmet through the hole already there by the manufactures, added springs in a twist motion through the air vents first spraying a copper color, copper color washers over every drilled hole, PVC Gears , Steampunk style Metal gears, braided hair with bone attached, and sprayed the helmet with a triple thick gloss finish.
Thank you for viewing
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Space Challenge
      Space Challenge
    3 Comments
    It's a general rule that editors like to see the steps broken up (step 1, step 2, step 3 etc) rather than put all in one step. Also add your pictures per step. This will help your 'ible get featured and get you more views! :)
    Thank you for your input. I am new to this and will do better next time...
    I think you're doing BRILLIANT and you have AMAZING ideas! Thats why I wanted to help ya out ;) Here's a couple articles to read to help you in your Instructable journey...
    how to write a good 'ible: https://www.instructables.com/id/How-to-make-a-great-Instructable/step17/Edit-amp-Expand/
    Tips to get your 'ible featured: https://www.instructables.com/id/How-to-Get-Featured/
    A checklist of what the editors look for to feature your 'ible: https://www.instructables.com/community/Featuring-Checklist/
    And finally, I wanted to tell you that you don't have to wait for another amazing idea to try again, you can fix this 'ible and let everyone know here (because editors are on here and may feature your fixed 'ible): https://www.instructables.com/community/The-Clinic/
    Blessings! And good luck! ? P.s. WELCOME to the Instructable community!!
