3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cyborg zombie evolution
Step 2Some no-soldering electronics
  • last photo ←
Instead of soldering you will be sawing, glueing, bending, cutting and screwing.
Saw through the middle of one of the connections of the connecting block (a bench-vise is handy). Clean out the sawing dust by blowing in the cut ant glue in the small piece of plastic sheet with (hot melt) glue.
Bend the legs of the transistor as shown. If your transistor has no EBC marking, you can work it out following the picture, knowing the leads should still be in the same order if it is the same type (in other cases check the datasheet). Bend the B(ase) backwards and C(ollector) forwards. Taking in account the dimensions of the connecting block, bend the end of these two legs down again. Cut the E(mitter) slightly longer than the bent down ends of the other legs.
Slide the transistor legs in the connecting block, making sure the B(ase) is in the connection cut through. Screw tight the C(ollector) and E(mitter), making sure the transistor legs take hold. Put in one lead of the resistor with the B(ase) leg of the transistor and screw tight. Bend the resistor well away of the transistor legs and towards the remaining contact, were you attach the resistor's other lead.
side).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:masynmachien(land, sea, air and space)
My main hobby is developing creative workshops for children. Since several years now I have been organising those, mainly voluntary at the school my daughter is attending. My workshops most often invo...
more »
