loading
Step 3: The Suction Part
As shown in the photo, cut a small block of plywood and fasten it to the center of the bucket lid. Using a hole saw or jigsaw, cut a hole through the plywood and lid that another piece of PVC pipe will tightly fit. Again, caulk with silicone. Use plenty - It is what holds the pipe in place.
The hose from the vacuum goes here. The pick up hose goes to the side connection. You have to come up with a second hose for this; I used a pool skimmer hose that I had. Then again, I keep all kinds of junk - you may not. In that case, you will have to buy something that fits.
mix a small batch of concrete or plaster in the bottom bucket.<br>let cure.<br>Instant fix to the low weight problem, without making it unmovable<br>(10-15 lb free-weight plate should work ok too.<br><br>An unintended benefit to this design is, it makes your standard shopvac into a high-class wet/dry shopvac!
<p>Occam would love your idea of using the bottom as a concrete mixing bowl and them simply leaving it to harden in place! Nice and clean. Pun fully intended. </p>
good idea. <br><br>I'd probably just get a small import brake drum from the scrapyard pile, but even some round smooth rocks would work.
That's a good idea. I probably have an odd weight I could use. I had also thought of doubling up on a triangle or square of particle board and using wheels on it. <br><br>You are right about the wet/dry benefit. I haven't tried it, but I would think it would keep your shop vac dry while sucking up spills.<br><br>Thanks.
<p>Any issues with static electricity buildup?</p>
<p>You could try putting a spiral in the top bucket like the one pictured here </p><p>. I think you could make one from another bucket lid </p>
<p>you can put a legging or something over the dustfilter it will keep the filter cleaner ond easy to remove the dust</p>
<p>What is the advantage to having the larger vs. smaller pieces separated? What's wrong with having them all in the same container?</p>
<p>It depends on what your are vacuuming up. In typical workshop applications, you get a very fine dust that winds up in the filter, a coarser dust that goes into the bottom of the shop vac, and a bunch of splinters and larger stuff that goes in the bottom tank. Separating the debris allows you to run the vac a lot longer before dumping it, and if you mount the cylonic part on a large (20 gal or so) container, it may be months before you have to dump that.</p>
<p>Here's a connector similar to the one on the side. </p><p><a href="http://www.woodcraft.com/product/2000899/9634/212-router-fence-dust-extraction-fitting.aspx" rel="nofollow">http://www.woodcraft.com/product/2000899/9634/212-...</a></p>
<p>You're right. That is a good substitute for the one I used. Thanks</p>
<p>Very nice, simple design! Where did you find the black, hose fitting mounted to the side of the bucket...that's an especially nice detail. </p>
<p>Rich:</p><p> I got the fitting off of a whole house vac that had kicked the bucket. It does make it a lot nicer. I haven't found any where to get a similar fitting, sorry to say.</p>
<p>Here's a similar one</p><p><a href="http://www.woodcraft.com/product/2000899/9634/212-router-fence-dust-extraction-fitting.aspx" rel="nofollow">http://www.woodcraft.com/product/2000899/9634/212-...</a></p>
<p>&quot;I already had the rubber boot from a whole house vac, but I wouldn't recommend buying one for several hundered dollars and throwing everything away but the boot. Just select a piece of PVC pipe your vacuum hose will fit into or around and cut the end on a 45 degree angle.&quot;</p>
A cyclonic separator is a huge improvement for any shopvac, and it really saves the filter and prolongs it's life. One thing I added to mine is on the bottom bucket, I cut a slot app. 2&quot; wide and from app. 4&quot; up from the bottom to app. 6&quot; from the top, and added a clear plastic window to the inside, using # 10-32 round head screws with flat washers. I also sealed the area where the clear plastic and bucket meet with clear RTV. You then can keep an eye on the level of debris and dump it before it gets too high. You are to me complimented on what you built, and I hope to see more of your suggestions and projects. Good job.
thanks for posting this. I like it. A lot. See if I can go pickin for some parts.....
I wonder if adding an elbow to the input side pointed downwards to put more distance between the input and the suction. Maybe giving gravity more of a chance to work on the debris.
The inlet isn't aimed at the outlet, it's aimed into a spiral to create a vortex.
It wouldn't hurt to try, but it works pretty well as it is. Unlike some of these devices I have seen the top (to the vac) side doesn't have a pipe running very far into the top bucket, so there is some separation anyway.
we took a second shop-vac that had a burnt out motor and converted the top to use the same way as this. Less work, and it had casters on it
cool thing about this design though is you could use the upper section and adapt larger containers for the bottom also you could use it both as a wet dry vac without having to change the actual vacuum over to wet dry. this is AWESOME and i do believe i will make one soon as i love to make stuff and always have a large mess.
Thanks. I think it would be better to have a larger bottom drum. I mainly wanted to see if the off the shelf components would work, and they do.
Nice and simple. I like it. <br>From what I've seen in other cyclone separators, I think the suction pipe step 3 should extend down into the bucket several inches. <br>I'm thinking that this might work great for the new lead paint requirements the epa has place on remodelers. We now have to clean everything up with a hepa vac. the problem is that these things don't have much volume for debris as they are mostly focused on the fine dust. so with something like this, you could capture all the construction debris and without filling up the expensive hepa filter.
Interesting. Can you estimate a percent of solid that go into the filter?<br><br>A device as this would be a good thing to my wood lathe. I did a homemade design, it was almost a complete failure: the container collapsed, the tubes rang horrifying, and then I abandon the project.
I would say perhaps 90 percent of the heavier material winds up in the bottom bucket, maybe more. I haven't tried it with a lathe, but I would guess the majority of it wouldn't make it to the vac. Same with the shavings from a planer. Those would be ideal situations for using a larger bottom container.
Thanks, you've convinced me. Soon I will have &quot;my&quot; workshop, today I work in the back balcony. Then I will make one od these contraptions.
This is absolutely awesome. Wish I had one of these when I was vacuuming out our sump. Might be nice to just toss the bottom bucket if you vacuum up something nasty enough.<br /><br />(Though I know that almost nobody who would do this would ever throw a five gallon bucket away.)
About This Instructable
142,325views
313favorites
License:
Bio: When I was a boy, I was amazed how my grandfather could make flotsam and jetsam into useful things. I am proud that I have ... More »
More by RangerJ:Rotating Power Tool Base Shield Your Wireless Router/Modem From RF Energy A Place for Everything
Add instructable to:
