Cykill – a Bike Powered Gaming Console
Introduction: Cykill – a Bike Powered Gaming Console
Invention Challenge 2017
Grand Prize in the
If you are eager to get fit but can't find the time or motivation – hack any console in this (possibly regrettable) way for fast results!
Cykill has been said to be America's BEST CHANCE at tackling child obesity.
The only way the gaming console will power on, is if you pedal the bike. Fail to pedal fast enough and Cykill will kill the power to your console. ☢ Possibilities of hard drive corruption ☢ Which should be enough motivation to keep you pedaling. (But don't worry, if you are concerned about wrecking your console's hard drive you can do the exact same hack to the tv/monitor instead)
It is a super super super super easy hack! Anyone can do it! All the work was in the code and that is already written for you ;)
Viral on Imgur >200k views:
Originally released Sept 2016 as a publication on IDEO :
Project of the week on Maker Lab:
Arduino Blog:
Step 1: What You Need
Step 2: Intercept Signal From Bike Wheel
With most cheap exercise bikes you will find two wires traveling from the front bike wheel into the interface. We need to intercept those wires. So cut them! Then connect them to your circuit. In the photo you will see I just used simple jumper cables.
Step 3: Remove Existing Interface
Just tear it off. We don't need it. All we need are those two wires.
Step 4: Create Your Interface
The Interface includes:
  • Toggle button for Arduino on/off.
  • Toggle button for workout start/finish.
  • Potentiometer knob and LED bar for intensity.
  • Potentiometer knob and LED bar for duration.
  • LED ring to monitor speed.
My laser cut files are attached.
Even cardboard will work if you want something quick and scrappy.
Step 5: Build the Circuit
Neo Pixel LED Ring:
Neo Pixel LED Ring, Data __ ARDUINO PIN 2
Neo Pixel LED Ring, Gnd __ ARDUINO GROUND
Neo Pixel LED Bar, Data __ ARDUINO PIN 9
Neo Pixel LED Bar, Gnd __ ARDUINO GROUND
Intensity Potentiometer Signal __ ARDUINO PIN A0
Intensity Potentiometer Power __ ARDUINO POWER +5V
Intensity Potentiometer Gnd __ ARDUINO POWER GROUND
Neo Pixel LED Bar, Data __ ARDUINO PIN 10
Duration Potentiometer Signal __ ARDUINO PIN A1
Duration Potentiometer Power __ ARDUINO POWER +5V
Duration Potentiometer Gnd __ ARDUINO POWER GROUND
Power Switch Tail:
Power Switch Tail Pin 3 __ ARDUINO PIN 13
Power Switch Tail Pin 2 __ ARDUINO GROUND
Toggle Switch Start/Finish Workout:
Toggle Lead A __ ARDUINO PIN 8
Bike Pins:
Bike Pin 1 __ ARDUINO POWER +5V
Bike Pin 2 __ ARDUINO PIN A2 (add resistor shown in diagram)
Toggle Switch On/Off Arduino:
Splice the ground connection of the Arduino power adapter, and connect ground to both leads on this toggle switch. (Alternatively, you can just always leave the Aduino powered on if you want to skip this)
Step 6: Eliminate Temptation
It's time for commitment.
Cover the female end of the Power Switch Tail with glue. Plug the male end of the gaming console power cable into the Power Switch Tail.
Do the same with the gaming console power cable where it plugs into the console.
If your glue is strong enough, temptation should be eliminated.
Step 7: Upload the Code
Code is on github –
Code has five states:
  1. startup (initialization)
  2. input (dial workout)
  3. running (workout running)
  4. game over (console shutdown)
  5. done (workout complete)
You may need to make some edits to the "level_reduction" variable depending on the speed of your Microprocessor.
Step 8: Done!
Congratulations! You completed the Cykill hack!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    This is so awesome. You should totally make, market, and sell this as a thing people can purchase. I'm a mechanical engineer and I totally followed along; I have no doubt I could (eventually) build this and get it working. I would still buy one. I like exercising and I like video games. I think that's pretty common.
    If you haven't looked into kickstarter or indiegogo, definitely check out launching a prototype there. Good luck!
    Thanks so much Luke. I feel the hack is so easy and affordable it is best suited as a opensource/DIY project.
    I agree with lukeg22woo! Turn it into a project on Kickstarter!
    Nice project. I really like the interface. What material did you use for the front panel? How did you create the blue type on it?
    Hey this is a really cool idea but why not just keep it simple and only plug the TV into it? No potential corruption issues that way. Not like you can play Xbox without the TV...Just a thought.
    It's a good fallback for sure. But I need the motivation of possible hard drive corruption. Keeps me pedaling fast. Like being chased by a bear, kinda.
    Suggestion 2, splice into the wires that tell the console to turn on. Easily done believe it or not. Considering you're using an arduino you could just interface with the motherboard. There should be a pair of pins, one is ground and the other when pulled low turns the console on or off. That way, it'd still turn the console off if you didn't pedal fast enough but it wouldn't corrupt anything because it'd turn off softly.
    This is amazing. Really, truly amazing. As an avid gamer and occasional cyclist I love this combination. I was actually tinkering with the idea of something very similar but rather than powering off the console my initial idea was to kill the video signal so as to prevent the afformentioned possible HDD corruption. Well done. Your idea gives me renewed hope in a project like this. Well written and easy to follow along with.
    This is awesome! I had an idea to do something similar while riding my exercise bike and watching TV - in the winter (Michigan). I'd much rather game than just watch TV but have lacked the knowledge behind the ability to pull something like this off without ruining the bike. Thanks for this great Instructable - will be developing soon!
