3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cylon Lights
Cylon Lights
The Cylon Lights is a little LED project using 8 red LED's that pulse in a pattern like the cylons in BSG.
This project was designed by hittconsulting. I revised the design slightly to work on our new project boards. You can get the kit from Gadget Gangster and download a PDF version of this howto.
Here's a quick video of the original version;
Warm up your soldering iron and get started!
Step 1Gather the Parts
Gather the Parts
If you'd like to gather the parts yourself, you'll need the following.
Parts list
  • Knob
  • 1x .1 Ceramic cap
  • 2x 10uF Electrolytic caps
  • 1x 28 Pin Dip socket
  • 1x Power connector
  • 1x 1n4001 diode
  • 1x SX 28 microcontroller (if you buy the kit, the SX will come pre-programmed, otherwise you can download the sourcecode from Gadget Gangster)
  • 8x 3mm Red LED's
  • 1x Gadget Gangster Boss Board
  • 1x 3.3v LDO regulator
  • 1x 10k ohm potentiometer
  • 3x 10k resistors (Brown - Black - Orange)
9 comments
Oct 28, 2009. 8:28 AMGoodhart says:
I was planning on building a similar project soon only with a 40193.
Nov 11, 2011. 5:29 PMblinkyblinky says:
A 4017 works just as well.
Nov 13, 2011. 12:52 AMGoodhart says:
I am not sure I have one "on hand" ;-) even though it is now 2 years later....
Jan 19, 2010. 12:17 PMjamar3030 says:
Is it necessary to use a SX programming tool to program the SX 28 or is there another, cheaper way to get the source code in? For $34 the programmer isn't a bad idea if someone is programming multiple IC's, but not efficient if they are just doing one. Thanks for the tutorial!
What language is this programmed in?
Oct 23, 2009. 12:18 AMthinkdunson says:
very cool.
you forgot to put the electrolytic caps on the parts list.
Sep 7, 2009. 9:22 AMvalhallas_end says:
Nice. If you put a plastic filter in front of the LED's, it would probably look very Cylon-ish. Incidentally, I just finished watching through the BSG classics on Hulu again.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
164
Author:Gadget Gangster(GadgetGangster.com)
