DANCING LED WITHOUT ANY IC,CAPACITOR OR TRANSISTOR
Published
Introduction: DANCING LED WITHOUT ANY IC,CAPACITOR OR TRANSISTOR
About: HI GUYSSS...I AM THE STUDENT OF CITY MONTESSORI SCHOOL CHOWK MY GOAL IS TO MAKE ELECTRONIC CIRCUITS WITH AS LESS COMPONENTS AS POSSIBLE. I'M EXPERIMENTING AND WORKING ON THE SAME. I HAD SUCCEEDED IN MA...
HI FRIENDSSSSS.....
This project work on simple LED series cuircit
BUT Tri colur led blinks it self which allows the current to pass on its own oscillation as a result the whole LED series show dancing effect .
Hope you like it.
(((((((((IF YOU LIKED IT COMMENT FAST OR IF YOU DIDN'T UNDERSTOOD ANY STEP ASK ME IN COMMENTS)))))))
Step 1: THINGS TO BE NEEDED
For this awsome project you will need
3 led(Tri colour led (recommended) blue and green (optional) .).
Bread Board.
9 v battery.
Battery holder
Note: you should have Tri colour Led as without this you can not build this project
Step 2: CIRCUIT DIAGRAM
On the basis of the same circuit diagram we will be constructing our project
Step 3: FIRST STEP
Take your circuit board and check each hole of it so that no problem occur in future in making the circuit
Step 4: INSERTING FIRST LED
Insert the blue LED in one of the hole of circuit board
Step 5: INSERTING SECOND LED
Insert the Tri colour LED in the circuit board and insert +ve terminal of Tri colour LED to the -ve terminal of blue LED
Step 6: INSERTING THIRD AND THE LAST LED
Now insert the green LED in the circuit board and connect the +ve end of green LED to the -ve terminal of Tri colour LED
By completing these steps you will be having +ve terminal of blue LED and -ve terminal of green LED
Step 7: CONNECTING BATTERY HOLDER'S WIRE TO THE CIRCUIT
Connect the +ve (red wire) to the +ve terminal of blue LED and -ve (black wire) to the -ve terminal of green LED
Step 8: PROVIDING POWER TO THE CIRCUIT
Now connect the Battery to battery holder
Step 9: RESULT
You will be having the dancing LED without using any IC OR CAPACITORS OR EVEN ANY TRANSISTORS
Step 10:
http://m.youtube.com/watch?v=QjiJgSN1uDo
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    14 Comments
    ohhh archit bhai aap kaise................................ how was my instrtuctable.
    Technically you use the ic that is inside the tri-colour led
    click on the link to see vedio or search on youtube "DANCING LED WITHOUT IC OR CAPACITORS"
    http://m.youtube.com/watch?feature=em-upload_owner&v=QjiJgSN1uDo&desktop_uri=%2Fwatch%3Fv%3DQjiJgSN1uDo%26feature%3Dem-upload_owner#
    First buy Tri colour Led and then make the circuit and then see if it works. BUT I will be uploading the video soon Because I don't know how to upload video here so I will be uploading vedio on YOUTUBE and provide you all the hyperlink of that vedio
    In Led series circuit the current is flowing continuesly so the whole series glow but not blinks BUT here the main work is of TRI COLOUR LED because it blinks itself to produce the three different colours
    Sorry. I don't understand the principle of this circuit. How could three leds on series to blink? Tri colour LED means leds with different colour or TGB led? The simplest way is to show us a movie. Thanks!
    Is a tri color led in essence just a RGB led?
    No the Tricolour LED blinks itself which allows the current to pass on its own oscillation on which the Tri colour LED itself is blinking as a result the whole line gets blink like a dancing effect due to oscillatory current which is flowing
    there are only 3 led in paralel this should light up all at once
    but if done right with caps u could make self powered 4 a few mins.
