3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DC Boost Converter
DC Boost Converter
My first intention was to design a DC Voltage boost converter to convert 3vdc to 5vdc so that I could power my iPod or any other device requiring 5 volts to charge.  I read about oscillation circuits and boost converter circuits and combined the two.  My results were staggering when I was able to convert 4.5 volts to over 100 volts by accident.  I decided to post an instructable for this instead, for now. If you have any tips to increase the efficiency or output current please comment below, I appreciate any suggestions.
Step 1Obtain Parts
Obtain Parts
All components can be found at RadioShack.
     PCB
     3 X 1.5 volt Battery Holder
     L1     RF Choke                   100 micro Henries
     R1     Resistor                      10 Ohms
     R2     Resistor                      51K Ohms
     Q1     PNP Transistor          2N3906
     Q2     NPN Transistor          2N3904
     Q3     Power MOSFET         IRF510
     C1     Capacitor                    .01 micro Farads
     C2     Capacitor                    .047micro Farads
     D1     Diode                           1N4148
59 comments
1-40 of 59next »
Jan 30, 2012. 7:58 AMamruth says:
how many amps come out from the output. Plz tell me waiting for a reply. Thx.
Nov 16, 2011. 2:38 PMUmniscient says:
Hi there, nice guide.
Suppose I removed the output diode. Would the modified circuit produce AC?
Dec 18, 2011. 11:10 AMKurt Gerhard says:
No, it will give the same voltage from the batteries
Nov 17, 2011. 12:02 PMZettu says:
i put this schematic together with every component the same the power source is two AA's at 3v 2600mAh roughly the output voltage is 6.48v by putting potentiometer for the 51kohm resistor and turning it down slightly i was able to get 7v however the current output is really low and i'm not sure it would be effective for charging anything on usb even with a voltage regulator on the output to ensure 5volts, i was thinking of maybe experimenting with the a zener diode near the output somewhere rated at 5volts or maybe 12v and regulator 7805 on it, but i wondering how you got 100v cause i have another experiment that involves high voltage and low current for illuminating a gas tube or even a small fluorescent off of 2 AA's ,,,, let me know what you think about these ideas maybe we can collaborate on some ideas,, :)
Jul 5, 2011. 7:58 AMN3v3rm0r3 says:
4.5VDC input, at what amperage? I don't want to use batteries...
Mar 26, 2011. 6:33 PMgerbil_man says:
Would this still be able to charge an ipod touch 3G?
May 8, 2011. 9:00 PMllamma1010 says:
The iPod's have a very weird charging system watch this video
http://www.ladyada.net/make/mintyboost/icharge.html
Dec 28, 2010. 5:36 PMInducktion says:
What kind of wave does it output? Square wave right?
Dec 3, 2010. 3:10 PMVicentiuB says:
how many amp output from this circuit ?
Sep 24, 2010. 4:18 PMjules15 says:
Will this work for 350vdc to say 1000 vdc (camera tazer)? If not how can I do this?
Sep 25, 2010. 12:59 AMARJOON says:
INSTEAD USE CAMERAs you can get approximately 60kv
Nov 20, 2010. 2:54 PMMudbud says:
uhm, Ive only gotten 300VDC outta camera circuits..
Nov 8, 2010. 7:29 AMAdam Manick says:
Wouldn’t 60kv volts arc across the transformer and destroy it. I highly doubt you can get that from a camera flash. Even a neon sign transformer can’t put out that much.
Nov 8, 2010. 12:49 PMARJOON says:
yeah i burnt mine instantaneously. that was crazy. when i opend the transformer. wire in the secondary was burnt. it was like dust.
Nov 8, 2010. 6:13 PMAdam Manick says:
Did you measure the voltage before it burnt out?
Nov 8, 2010. 9:31 PMARJOON says:
no i did not that was quick.
Sep 25, 2010. 4:52 AMjules15 says:
I don't understand.. I'm already using a camera
Sep 25, 2010. 10:15 AMARJOON says:
on your first circuit in the camera. remove the capacitor and instead place this transformer from another camera.(must be alike)
solder pin 1 to one lead of the cap outpuit
then solder pin 3 to the other lead.
then you will get an output more than 60kv (more than enough to kill) in pins 4 and five.
i've never tried but if it works pin 4 and 5 will be arcing a lot.
Jul 29, 2011. 8:14 AMankitgarg2005 says:
I need to convert a 6v 4.5A battery into 12v that can give around 2A or more current
any schematic? Voltage doubler circuits on the web gives around 100mA which is not sufficient for motor driving. Thanks...
Jul 29, 2011. 9:51 AMARJOON says:
try using an oscillator n rewind a small 1:1 transformer to 1:2 n u may get it
Jul 29, 2011. 11:09 AMankitgarg2005 says:
Can I do this with some IC ? I don't have much knowledge of transformers.
Jul 30, 2011. 12:07 AMARJOON says:
use the so known 555oscillator. amplify through transistor or mosfet which in turn will drive the transformer to double the voltage. don't forget to rectify the other end
Jul 30, 2011. 9:42 AMankitgarg2005 says:
sir can u provide me the circuit diagram please.
Jul 30, 2011. 10:12 AMARJOON says:
u can use this circuit. but reduce the frequency to about 40-75Hz. this will enable you to use a normal transformer.
Sep 25, 2010. 10:29 AMjules15 says:
Ok thanks a lot ill try it
Nov 12, 2010. 8:49 PManvit says:
How did you calculated the value of the capacitors .?
can we replace them by any other values ?
Nov 4, 2010. 8:38 PMV1x0r says:
Soooo...because I was having a hard time with initial directions I made this little "Solder directional based off of MOAL's pdf.
Thanks for the Tut btw!!!! I'm excited to get this finally put together!
(Q1a - L1a - R1b) --> power Input
(Q1b - Q2a)
(Q1c - C1a - R2a)
(Q2b - R1a - Q3a - C1b)
(Q2c - C2a - Q3b - R2b)
(L1b - D1a (side w/o black strip) - Q3c)
(D1b - C2b) --> power out
Please correct me if i'm wrong.
I don't know which ends connect to the grounds. >_<
Nov 4, 2010. 8:45 PMV1x0r says:
(Q2c - C2a - Q3b - R2b) connect to a ground. Correct?
Nov 8, 2010. 12:46 PMARJOON says:
i messed up with datasheets on my pc that is why it got all screwed up now this new pcb design is the good one.
Nov 8, 2010. 12:40 PMARJOON says:
I AM SO SORRY. i made it now and tested it. this now is sure the good one. i forgot to add wires and the transistor pinout was incorrect. now this pcb is nice and no error.
BC.pdf(595x842) 4 KB
bc2.pdf(595x842) 3 KB
Aug 3, 2010. 5:24 PMsilencekilla says:
Does it charge capacitors? and we have the same brand and style multimeters just different model types
Oct 18, 2010. 8:03 PMsilencekilla says:
big reffering to volts or uf?
Oct 19, 2010. 2:35 PMsilencekilla says:
would you be able to post one that will charge up to 1 farad or if not what about 1/2 Farad?
Sep 14, 2010. 2:16 PMqazwsx755 says:
Great Instructable! I have 2 questions for you how many amps dose your DC Boost Converter output and how many Hz is your RF choke?
Sep 26, 2010. 10:57 AMARJOON says:
and here is the pcb. if the inductor don't fit. mount it vertically. it works great
bst2.pdf(595x842) 5 KB
bst1.pdf(595x842) 7 KB
Sep 26, 2010. 10:51 AMARJOON says:
hello there here is a neater shematic
Aug 22, 2010. 2:37 PMdevinmccloud says:
I believe it is the amperage that kills not voltage!
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:krmartin3
