Introduction: DC Versus AC
Direct current (DC)
In a DC (direct current) circuit where the electricity flows in one direction, we can think of a battery as a storage tank like the water tower in your neighborhood. If nobody turned on their faucet, the water in the tower would just sit there. Forever. Physicists like to think of this as "potential energy." Like a boulder at the top of a hill, it will just sit there, forever, until someone pushes it over the hill or an earthquake shakes it from the top of the hill or erosion undermines it starting it to roll down the hill. When the boulder is rolling down the hill, physicists like to think of this as kinetic energy. So, the water will just sit in the top of the water tower until you turn on the faucet to your water hose. The water will then flow from the top of the water tower through your water hose and then on to the ground. You can then think of the flow of water as kinetic energy and this kinetic energy can be used to do useful work.
When no circuit is connected to your battery, it is like a storage tank, or potential energy. When a circuit is connected to your battery, you can think of electrons flowing through the circuit as kinetic energy that can be used to do useful work such as light up an incandescent light bulb or light emitting diode (LED).
You can thank Ben Franklin for a bit of confusion that often arises regarding electron flow and current flow. Franklin studied electricity before the discovery of the electron and simply had to guess—and he guessed wrong—so, current flow is backwards. Electrons have negative charges and flow in the opposite direction of current. Confused? No worries. Just stick with “current flow” (also called “conventional current” or “conventional electricity”) and think of “current” flowing from the positive ("+") terminal on your battery to the negative ("-") terminal, or ground, like the water flowing from the top of the water tower, through your garden hose, and onto the ground.
Step 1: Alternating Current (AC)
Alternating current (AC)
Direct current by definition flows in one direction. Alternating Current (AC), on the other hand, periodically changes direction, or reverses polarity. To use a diving analogy, imagine a scuba diver. Since scuba divers carry their air with them they can still breathe whether their heads are above water or underwater. You can imagine a scuba diver surfacing and diving repeatedly and the path he or she traces forms a sine wave.
The sine wave is what Alternating Current looks like. At the crest, or top of the wave you might measure +5 volts and at the trough, or bottom of the wave you might measure -5 volts. At the line through the middle you would measure 0 volts.
Step 2: Check Valve
It is indeed possible for a portion of a circuit that is normally DC to periodically change direction, or reverse polarity like an AC circuit. Examples can include some 555 timer circuits and circuits that drive DC motors. Some electronic components can be sensitive to reverse polarity and can be damaged by sending electricity through them the wrong way. To protect these components, you can install a diode in the circuit.
According to Wikipedia, “The most common function of a diode is to allow an electric current to pass in one direction (called the diode's forward direction), while blocking current in the opposite direction (the reverse direction). Thus, the diode can be viewed as an electronic version of a check valve." (Source)
What is a check valve? You can think of it like a ping pong ball cage snorkel. When the ping pong ball cage is above the surface of the water, the ping pong ball is at the bottom of the cage and you can breathe through the snorkel. As the cage moves below the surface of the water, the ping pong ball floats up until it blocks the opening of the snorkel blocking any water from getting into the snorkel.
We can use the diode to convert Alternating Current to Direct Current. Now imagine our snorkeler surfacing and diving. While the ping pong ball cage on the snorkel is above the water the snorkeler can take a breath of air. When the cage sinks below the water the ping pong ball blocks the water from getting into the snorkel and the snorkeler has to hold his or her breath until surfacing again to exhale and take another breath. Like the ping pong ball acts as a check valve to prevent water from getting into the snorkel, the diode acts as a check valve to block the voltage from flowing in the reverse direction.
You would measure from 0 volts to +5 volts then back to 0 volts. You wouldn't be able to measure the voltage reverse direction from 0 volts to -5 volts because it is being blocked by the diode. When the Alternating Current cycles back to 0 volts you would then be able to measure the voltage from 0 volts to +5 volts and then back to 0 volts.
Step 3: Build a Simple Circuit
You can build a simple circuit to demonstrate how a diode works.
Parts Needed:
Breadboard
4.5 volt battery holder
LED
Diode (I had a power diode in my collection)
Orange breadboard jumper wire
White breadboard jumper wire
Brown breadboard jumper wire
NOTE: the photos were shot using my Jewelry Box Electronic Survival Kit
Once you've got the circuit connected up the red LED will light up as expected (see schematic and picture above). Since the diode is in the forward direction, current can flow from the positive (+) terminal on the battery through the circuit to the ground (-) terminal on the battery.
Step 4: Now Reverse the Diode
Now reverse the direction of the diode (see schematic and picture above). The LED is no longer lit. Why doesn't the LED light up? Because the diode is blocking the flow of current like when you put a kink in your water hose which will stop the flow of water out of the hose and onto the ground.
Epilog Challenge VI
Teach It! Contest Sponsored by Dremel
Tech Contest
