history:
V1.0- Made as something when i was bored, never took it apart.
V1.5- I modified it for some more power
V1.75- Added Perfect Duck's pistol grip
V1.9- Added a true trigger mechanism and a better barrel
V2.0- Significant changes to the front barrel were made, stock was added.
V2.1- Heavily fortified the front of the barrel.
V2.5- Added barrel extension to make it shoot greys harder then the other red rod ammo.
V2.75- Nothing big but i added a chain on the top
Believe me, the power of this thing is unrealistic and you will never truly understand the power without making the gun.
It gets all this power from three things.
1. The barrel does not have that much friction, it still has friction but with only 12 connectors composing the entire 1 foot 2 in. long barrel.
2. It uses the KILLERK pistol type mechanism were the bullet is held in exactly were the ram will make contact with it. But mine is better. There is 1 in. of space between the ball joint(note i used a light grey connector instead of a ball joint) and the connector before it. So the gun does not lose any power before the ram hits the ball joint. Normally it would hit the side of a connector and have to go through the hole in it and that would line it up with the ball joint. And then the ram has to push through the sides of the ball joint. With no connector before the ball joint the ram just glides over the the ball joint, not losing any power, but still hits the rod, firing the gun.
3. It has almost a complete draw back of the firing pin. The block is exactly one grey spacer after the tan lock that holds the ram back. If i moved the block one blue spacer up the firing pin could not be pulled back far enough for the block to engage. This helps because the firing pin has almost a entire grey rod length to speed up and gain momentum that ultimately gives the gun power.
stats:
standard round (grey rod)-80-100 feet
sharpened rod 70-90 feet
grey connector on grey rod -accurate to 60 feet!
2 3d blue 7 slot connectors with blue clips all over on it connected to grey rod- 40 feet shrapnel 10 feet away from bullet
stats were taken with two #64 rubberbands tied togeather.
ranges and power may vary.
Please comment and rate!!!
Remove these ads by
Signing UpStep 1Gather your parts
RODS:
green-----------------------37
white------------------------100
blue-------------------------18
yellow----------------------15
red--------------------------1
grey-------------------------2(black recommend)
CONNECTORS:
dark grey------------------16
light grey------------------5
red/granite---------------45
green----------------------11
yellow---------------------49
orange--------------------35
white-----------------------22
EXOTIC:
tan locks------------------2(one needs to be weakened, see Perfect Duck's twin pistols to find out how)
black hands--------------18
hinges---------------------2
ball joint ball-------------1
blue spacers------------21
grey spacers------------14
flexy yellow rod---------1
OTHER:
tape
*Subject to counting errors
Also, you have to make sure the bands are very balanced. If they are puling the firing pin even slightly to one side or the other that will seriously hinder performance.
You should also note, I have much much more K'NEX then is in this gun, butI don't see how that effects the gun at all.
DSMan195276
I seriously recommend building this gun without just because it's really bad. Now the next version of the gun that i made(the Ible for it is probably coming soon. I don't know, I've been saying that for who knows how long now....) has a pin guide because the stock is strong enough to not bend. In that case it probably does help a little, and makes the pullback easier.
I'd be allot more enthusiastic about the NAR if Ooda actually put some thought into how he dispersed the impact instead of shoving a piece in the barrel to take the entire impact force.
Second, I really don't care if you think that the NAR is better then this. And if you do, why are you bothering to even post on this gun? AND you went as far as to tell me to "hurry up and post it".
As for the ball joint, you got me that I can't say from experience that I've ever had a ball joint break(I never wanted to risk a ball joint to test it, since I have a limited amount of them) but I have plenty of friends from instrucatables that have told me that their ball joint broke. I have no idea if they put it in the right way or what ever, but there smart so I imagine they did. Saying "the ball joint won't break" is a pretty bold statement.
Honestly if you like the NAR so much, then go build that.
And it's great to know you support this, but i'll let you know right now that I DON'T support putting Ooda's 'ball joint' power taker thing. If I do make something like that I'll actually have it suppress the power instead of just bluntly take it.
As for it sounding 'wimpy', it'd get the same amount of force Ooda's ball joint can. Just without the chance to break your pieces.
Basically, it'd work like this:
Fire the gun
The Firing pin hits the end of the bullet, firing it. Right after that, the suppressor kicks in, and stops the firing pin from moving so fast. Kinda like if you replaces the front of the gun with Styrofoam. Obviously the implementation of such a system would be nothing like styrofoam, but it would cause a suppression effect close to that type of material.
I honestly don't see how anybody can object to a system like this. If nothing it's just another advancement we can make in the realm of K'Nex Weaponry.
DSMan195276
The problem with that system though is that something like that would tremendously reduce the amount of energy being transferred to the bullet since it would "Absorb" more power than the balljoint on the NAR.
Also, the front of the gun (The parts after the balljoint) take the force, not just the balljoint itself.
Happy building :-)
1) scrap BRKWB2 for parts
2) eBay!
3)no stock :(
k, wait I see hinges. looks like I'll need more anyway... TO THE EBAY CAVE!!
www.instructables.com/id/Knex-Through-14-Wood/
You could shove 8 RB's on this gun if you wanted and I garentie that it would shoot even harder then that gun(Though the back would implode...).
Thats also shooting Red rods, which are smaller.Though that probably doesn't make a huge difference, it's really hard to say with knex rods. The only thing i can guess that might happen is grey rods would bow out a lot more then reds before actually starting to puncture the wood.
According to your logic, the answer is yes.
According to everyone else (insofar as I can tell), the answer is no.
X is not more powerful than Y. X has a max distance of 20 feet, while Y has a max distance of 150 feet. Ergo, Y is more powerful.
1. Just because gun y can HOLD 10 band does not mean that it's practical by any means. The TR can shoot through wood with 8 bands sure, but the pull back and bend of the entire gun just makes it impractical to call that a max range. Like I said, I could just as easily put 8 bands on this, but it's just impractable.
2. The difference in how many bands each can take does not differ as much as you think. I normally just use 2 bands on the DD-27, but it could easily hold around 6(I have trouble pulling that back).
3. Again, I will say that this is subjective. I think the big problem with your logic is that there is no max distance. Who says that the TR can only hold 8 bands? and who decides how many bands qualifies for max distance? I can tell you right now I am not strong enough to pull back 8 bands easily with out taking off some of the bands and putting them back on, which would make my max distance smaller then yours, and the max distances of these guns for me much closer.
4. The third thing is ammo. I can only fire grey rods making my ranges smaller already. You would get different max distances for each type of rod and the TR wouldn't be able to fire grey rods straight making it unfair for the TR to use them for any type of max distance measurement.
Thats why I like to use power as power per rubberband. power per rubberband is measurable and overall distances would be a better measurement(no variable of number of rubberbands). Of coarse it's not a perfect way of measuring power, but there isn't really a perfect way is there?
2. I was not referring to these two guns in particular. I was pointing out the flaw in your logic; that power is measured per band, instead of the amount of power the gun can take before breaking.
3. There is a max distance. It can be found using physics. It can be easily determined by the number of bands you can put on before the gun breaks. In the case of the Untangle, the pin will snap before the body of the gun breaks. Just because you can't get the 1 MOA groupings an M24 is capable of with M118 ammo doesn't mean that the gun is any less accurate; it just means that you happen to be an inept shooter.
4. Grey rods suck for ammo. Why are you using grey rods? They lack stability. And again, I am not referring to power of a gun with a particular ammunition, or even any two particular guns.
Power per rubber band is not directly proportional. It will level out eventually; maybe not before your gun explodes, but eventually.
1. I know there are flaws to this type of measuring, I said that in the last sentences in the last comment.
2. You do realize the obvious flaw in your thinking right? If the firing pin breaks from bending before the body, then won't almost every gun hold the same amount of bands? if the pin breaks from bending then it's going to do that with the same amount of bands on every gun meaning the only thing that matters is the distance per band because every gun can hold the same number of bands. The pin on the DD-27 will break from bending long before the barrel even comes close. That would mean in theory that using the same type of firing pin we should be able to hold the exact same amount of bands.
4. Greys only suck on guns like the TR with no extended barrel. With the DD-27's long barrel greys get really good ranges, power, and accuracy.
