loading
Step 14: Glue into place and test
Then glue the light switch base into the cutout on the interior wall with silicon glue. I imagine that a glue gun would also work in this case, but you´d have to be carefull no to melt any of the plastic parts. Also i had to file down some of the edges to make for an easier fit, with the dremel that´s a sinch. Once that was in place i tested out the connection again before closing it up completely.  If the test is successfull then go ahead and glue the interior and back walls down onto the base with more silicon glue.  The switch should fit tightly between the two walls.
Well done. I like the use of fiber optics in this project and how you constructed the lamp completely instead of leaving open ended ideas. Enclosing the case and adding a clean switching device makes it look marketable.
Thanks. I´m glad you liked the lamp.
About This Instructable
14,357views
31favorites
License:
More by jean v:Pine & Denim cricket Modular furniture system DEFECTO lamp project
Add instructable to:
