Introduction: DHT11 Sensor With E-Ink Display Module
Picture of DHT11 Sensor With E-Ink Display Module
Quickly and easily display your air’s temperature and humidity with a DHT11 sensor, an E-ink display module, and an Arduino Uno. This method will have an update on a 5-second loop so you get updated results continuously. Once you unplug the module, the last update will remain on the screen until you change the code or re-plug the display so it can update again (everlasting e-ink!)
Ready to get started?
What you’ll need
Hardware:
Software:
Step 1: Hook-up the DHT11 and E-Ink Display to the Arduino
Picture of Hook-up the DHT11 and E-Ink Display to the Arduino
You can see in the picture above the E-Ink display module's pinout. Here are the connections you should make:
DHT11 > Arduino Uno
VCC > 3.3V
Data > A0
GND > GND
E-Ink Display > Arduino Uno
GND > GND (either is fine)
SDA > D11
SCL > D13
CS1 > D6
D/C > D5
3.3V > 5V
BS1 > D8
BU/Busy > D7
RES > RESET
Step 2: Run the Example Code
Picture of Run the Example Code
Now that we're set up, let's run the example code you can get here. Remember to select the right PORT and BOARD in the tools tab.
E ink display library
Step 3: Read the Output
Picture of Read the Output
After you upload the code you'll be able to see the data come up on the E-Ink display module and reset every 5-seconds while powered up. You can remove the power and retain whatever the last update showed for as long as you like!
About This Instructable
226views
9favorites
License:
Bio: We're a group of fun-loving, electronic DIY'ers with Smart-Prototyping.com. We hope to share useful guides and tutorials as well as the cool ... More »
More by Alex_chu:Use Bluetooth 4.0 HC-08 Module to Control Addressable LEDs - an Arduino Uno TutorialHow-To Get Started With Addressable RGB LEDsGY-68 BMP180 Barometric Pressure Breakout Board Tutorial With Arduino Uno
Add instructable to:
