DIY: Bicycle - Steady Cam - mount
I wanted to shoot some video while riding my road bike, but didn't want to deal with a helmet mounted camera and of course I didn't want to hold the camera in my hand. An initial attempt at mounting the DV camera was totally unsatisfactory, so my next step was to build my own "steadicam" camera mount that would absorb some of the shock, providing a better quality video.
Step 1Part required
Part required
All of the parts are available at a well stocked hardware store. Most of the parts came from one of the following: The Home Depot, Ace Hardware or Blain's Farm & Fleet. All totaled the parts came to ~ $45.
QTY Description
5 Stanley Strap hinges (this brand has bushing that keep the hinge from wobbling)
1 3" Pulley
1 6" x 6" "L" angle bracket
1 PKG Clear Bumpers
1 PVC "T" - 1-5/16" Inside Dia.
1 PVC "reducer" fitting 1-5/16" to 1"
1 4" x 4" "L" angle bracket
1 EXT Spring 1/4"
1 EXT Spring 3/8"
2 1-1/2" Dia. Hose Clamps
1 PKG(2) Rubber Washers
1 PKG(10) 1/4"-20 nuts
1 PKG(4) 1/4"-20 lock nuts
1 PKG(20) 1/4" lock washers
1 PKG(10) 1/4" brass flat washers
2 3/8"-20 nuts
1 PKG(4) 1/4" flat (fender) washer O.D. 1"
1 PKG(4) 1/4" Bolts (1/4" - 20 x 1")
1 PKG(4) 1/4" - 20 x 3/4" countersunk bolts
1 3/8" x 1-1-1/2" machine bolt and 3/8" lock nut
1 PKG(4) 1/4" - 20 x 1-1/2" machine bolt with flat allen head
1 PKG(5) 10 - 32 x 1/2" machine bolts and nuts
1 PKG(10) #10 lock washers
1 PKG(10) #10 x 1/2" wood screws
31 comments
Apr 27, 2010. 3:41 PMthytum says:
hi, i didn't understand so weel about the 2nd swing arm, why does it have some metal's on side?
thanks =)
Jul 10, 2009. 8:27 PMwmstadler says:
Rube Goldberg would be proud.
Jan 27, 2008. 6:55 PM8thDay says:
I'm thinking of building something like this for my power wheelchair but without the pivot assembly
Aug 25, 2008. 1:53 PMcdmvsf says:
did you make one in the end? I am trying to do the same - any luck?
Jul 6, 2007. 6:35 PMSteveUK says:
This could be useful for tracking shots in amateur films. In professional films they lay down little railway lines and the cameras move on those. A bike being moved slowly with one of these on top would be a much cheaper solution.
Mar 23, 2007. 3:45 PMJohn Smith says:
Extremely nice. Only one problem - what if you crash?
Mar 8, 2007. 6:24 PMgeorgemorgan says:
Thanks Very Much. I really appreciate the picture design and test. I agree with Mr. Fireballx15. A dual iso-elastic arm will help a fare bit I think. I love all the sharing that goes on in this site. Cheers
http://www.lightofdae.com/home.htm
Jan 20, 2007. 8:54 AM1noriko says:
you can try using r/c shocks with springs and oil damping. you can also remove the spring and just use the damper on the pivot assembly.
Jan 1, 2007. 7:46 PMmustaphabarakat says:
[Removed by author]
Dec 19, 2006. 2:01 AMuaw7u64 says:
(removed by author or community request)
Jul 22, 2006. 3:56 AMatomheartfather says:
Nice project. Some of us bikers on the other side of the pond are trying to develop a similar thing, though with much less technical know-how! I found mounting on the handlebars added a lot of movement compared to on the frame, especially at turns. You can visit us at http://bikedarlington.blogspot.com/. Happy biking, all!
Jul 7, 2006. 7:12 AMravn says:
Cool project, would you consider making one to sell to me? :)
May 31, 2006. 3:10 PMcgrossmeier says:
Have you thought about a small set of gyroscopes? It seems that you could dampen much of the vertical and horizontal motion with some active stabilizataion. Mount 2 or 3 gyros so they spin on different axises. A small set of motors with weighted spinning platter connected to a D cell battery may dampen the motion enough to make this a small, portable, and cheep solution that can compete with the semi-pro stuff. The springs would provide support and basic stabilization while the small gyros could provide the last little stability you are looking for.
May 22, 2006. 10:02 PMturbovolv says:
If it's strong enough to support, adding a counterweight directly underneath the camera would help prevent the side to side rolling motion.
May 31, 2006. 7:03 PMMyself says:
Just move the camera's center of gravity even lower relative to the pivot point. You'll gain stability without added weight. As for the annoying pendulum effect, viscous dampers are the traditional method, but they're hard to build by hand. (If you do, consider silly putty.) You might scavenge one from an old tape deck that has a soft-opening lid, where a curved rack attached to the lid engages a tiny pinion protruding from a viscous damper. Dustbuster's syringe idea sounds right, if you replace the rubber seal with something slipperier and semiporous.
May 23, 2006. 3:14 PMbacktalker says:
Looks very nice. Would you consider replacing the large pulley with something that spins freely but doesn't have so much play in the unwanted directions? I'm thinking of an in-line skate wheel with it's bearings intact. And for a dampener, you might consider a spring-loaded pad that presses against the pully (or skate wheel). The spring could be adjusted for the desired amount of dampening, or changes in the counterweight under the camera. The pad material would be compatible with the pulley/wheel, in that it slips at low pressure, grabs at high pressure, and doesn't abrade too much. Felt, perhaps?
May 23, 2006. 2:02 PMdustbuster7000 says:
What you have at the moment certainly seems to be an improvement on a basic hard clamped setup, especially on less-than-smooth roads. Adding some weight to the swinging part might help, but its also possible that you'll substitute short fast swinging for slower longer swinging (which might be okay!). You have a simple harmonic oscillator at the moment, so you need some damping. I'm not sure from the photos if the wire over the pulley is there to provide friction under spring tension and reduce "free swinging" or whether the springs are directly connected to the pulley. If its friction based, try increasing the spring tension until the camera only just pivots under it own weight. If its directly connected, try adding something to use up some extra energy during the rotation, maybe forcing air out of a syringe or compressing some soft rubber foam. You might find tuning this tricky, but damping is about wasting some energy so that its not available to push the object back to where it started in the return half of the movement. Good Luck and keep us posted
May 23, 2006. 8:42 AMMark Rehorst says:
Looks like a big improvement! The real test will be to put one on one of the alley-cat racers in NYC and see how it does!
May 23, 2006. 8:35 AMdfault312 says:
It seems like your basic idea is to convert all of the sporadic movements to rotational movements (rocking) and then slowing that down by adding inertia (a conterweight) Let us know how the conterweight goes.
May 22, 2006. 11:52 PMfungus amungus says:
I'm curious to see what the ffect of the counter-weight is as well. That rocking motion is a lot. You look like you're getting close. Also, how is the footage without the pivot assembly? Since you're not going to be going that fast the tilting of the camera into the turn can accentuate the feeling of speed. On second thought, scrap that, there's sure to be some lateral jiggling as well on any riding. But the counter-weight would give you some tilt from the inertia.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:fireballxl5(In the bike lane)
I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together.
