DIY: Bicycle - Steady Cam - mount
Step 5The Handlebar mount
The Handlebar mount
1) Start by cutting the PVC "T" joint lengthwise through the middle (See the detailed diagram with the "cut line")
2) Place the PVC reducer fitting into the top of the T as tightly as you can.
3) Pre-drill two 3/32" holes through the T and adapter for the two screws and install the two screws.
4) Next place the 1/4" bolt through the "L" angle bracket, rubber washer and through the neck of the T. This is to check the length of the bolt as it will need to be cut. See the notes in the diagram.
5) Once the bolt is cut to length, assemble the parts as follows (per the diagram).
6) First the bolt goes through the "L" angle bracket, then the rubber washer and through the top of the PVC "T" and reducer.
7) Now from the bottom insert two (2) 1/4" x 1" fender washers against the lip of the reducer fitting and push the bolt through.
8) Now you can place the lock washer over the end of the bolt and start threading the 1/4" nut.
9) Tighten the nut and bolt until the bracket is snug against the PVC fitting.
The handlebar of my bike has a wrapping around the metal bar, so I just clamped it directly to the bar.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:fireballxl5(In the bike lane)
I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together.
