DIY: Bicycle - Steady Cam - mount
Step 9Testing, tweaking and possibilities
There's a few things that I'll change or modify...
1) Change to a quick attach, both for the whole assembly (replacing or modifying the PVC clamp) and for the camera.
2) Pivot is too loose as you can see in the video. I may do somethings along the lines of a gimbal (on a single axis) with a counterweighted camera mount.
2.a) New as of 5/27/06 - I'm changing the pivot to be another iso-elastic arm, see the new diagram below (hope to have this completed and tested over the Memorial Day weekend.
3) I need to tweak the weight or springs. Currently the springs are over compensating for more than the weight of the arm, sled and camera, so I need to add a little weight or find a different spring.
Possiblilities.
The iso-elastic arm was surprisingly inexpensive; ~$2.30 per hinge, $2-$3 for hardware and $2.50 for a pair of springs, so a dual-segment iso-elastic arm could made for around $30 in parts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:fireballxl5(In the bike lane)
I've always been a maker, mod-er, and tinkerer. I started out by taking things apart and then trying to put them back together.
