3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY - Replace Broken Laptop LCD
Step 7Install The New LCD
Install The New LCD
This should be fairly straight forward. Just reverse the procedure of removing the old one. Try to avoid touching the face of the screen. Some laptops have another screen in front of the LCD. This would make it hard to remove fingerprints!
Note that the shield behind the LCD is sometimes a little tricky to fit. Take your time and make sure it's reinstalled the same way it was originally.
Replace connectors and tape wherever possible. Add tape if you need to. Also assure that all wires are where they belong. We really don't want to pinch and damage wires when we put the cover on.
6 comments
Jan 13, 2009. 12:07 PMkikioncloud9 says:
UHHHHHHHH........ Im lost... :(
Apr 24, 2007. 12:40 PMDragona says:
"That LCD should work in a 12" iBook"* *You meant my powerbook right? Thanks a Lot! Congratulations about this tutorial and thanks for also DVRFlash, this great stuff makes you legendary!
Apr 24, 2007. 11:28 AMDragona says:
Hi, A very essential question please: As the powerbook 12" 867 mounts the old LCD you replaced (lp121x04). Do you think i can mount the LTN121X1-L02 on my powerbook. Thanks so much!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:LasVegas
