3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY - Replace Broken Laptop LCD
Step 9Test It!
Test It!
Now's the exciting part. Reinsert the battery and power. Now turn it on.
Hold your breath! It might take longer than you expect. If all went well... You'll see the display. It should need no adjustments since it's unlikely the settings have changed since the old one was broken.
Likely, because all power was removed for a period of time, you'll have to reset that time and date. Not a big deal, is it? :)
Note: The child belongs to the owner of this iBook. I don't know any details... Cute though, huh?
16 comments
Apr 17, 2012. 3:12 PMpblanscet says:
Thanks a bunch! I'm planning to repair a laptop for a friend, and this was all the enlightenment I needed to do so!
Oct 13, 2010. 9:08 AMlithodir says:
Hey, I was wondering - I have an old ibook G4 with a good LCD but an old operating system. I was considering buying a used ibook G4 with a higher operating system, but a cracked LCD and putting my old screen into the cracked screen. One issue is that I inherited my ibook from my sister, who bought it in New Zealand and I have a power converter on the end of the plug in for the power cord, but everything else seems the same - do you know if they all use the same parts all over the world? Assembled in Taiwan model A1055 - if that's helpful... I'm really keen to try this! Thanks!
May 16, 2009. 2:44 PMinrumford says:
Is there a way to tighten the hinges as the lid has a tendency to fall back a little
May 16, 2009. 8:00 PMbweezy says:
LasVegas, I replaced the LCD on my Compaq Presario A900. The screen works fine, but now windows isn't functioning correctly. It's mostly non-responsive and I can't even get it to shut down on it's own, I have to do a hard reset. Any ideas?
Jul 29, 2009. 1:13 AMKasm279 says:
install linux?
Jun 30, 2009. 11:23 AMkalizascope says:
So.. just replaced the LCD on my iBook G4 (it got run over by a semi). The install went pretty smoothly.. but when I turned it on - there were multiple images of the desktop on the screen and the right 1/3rd of the screen was black. It would stay on for a minute and then go to sleep (this could be because of battery being low) BUT I'm at a loss of what to do now.. :( Any help would be grrrrreatly appreciated!
Jun 30, 2009. 7:35 PMkalizascope says:
Thanks for the quick reply! I took it to a mac guy here in town and he verified that screencountry.com sent me the wrong screen - and that the going to sleep issue was because the power adapter's pin had broken off inside the computer (I tripped over the cord awhile back.. of course.. ah.. I'm brilliant!) Anyhow - he fixed the whole thing for about the same price I paid for the darn LCD. Niiiiiiice :)
Jul 29, 2009. 1:06 AMKasm279 says:
lol, nice
May 23, 2009. 8:43 PMelyseainsworth says:
Your instructions were so helpful! but we ran into a small issue, when we booted up the Ibook after replacing the screen, it lit up but doesn't show anything from the desktop, its just gray. Any suggestions?
Mar 10, 2009. 4:14 PMJGwizdz says:
Hi Las Vegas; Well I did everything you said (mine is an HP Pavillion) and while it powers up and shows Windows XP with the flowing status bar - it then goes black and does not refresh to anything. Suggestions?
May 16, 2009. 2:13 PMosurfc says:
Mr Vegas, My LCD went black (you can still see the desktop faintly) on my inspiron 6000 and I want to by the LCD on ebay and replace it myself using your how-to. I found one with the exact same specs but with a slightly lower resolution for very cheap. The manufacturer (dell) is telling me I need to replace the LCD with the same exact LCD or it won't work. Seems to me if the size, bulb, connectors are the same and the only difference is the resolution I should be fine. What's your take? Thanks!
May 16, 2009. 5:30 PMosurfc says:
I don't believe the replacement LCD comes with a new wire and inverter. Can you order these items seperately? Also, can you please advise on the resolution issue? Thanks!
May 17, 2009. 6:50 AMosurfc says:
One more thing. The display is fine for about 30 seconds (i.e dell splash screen, windows splash screen and then it fades to black). Would this be furter evidence of the inverter?
May 20, 2009. 7:11 PMosurfc says:
Well, I got screwed again by a power seller on ebay. I purchased the inverter and installed it today. The machine boots up fine but now the screen is red all over. I checked the part number on the inverter the seller said was compatible with my laptop, however, the part number is different. Has it been your experience that the exact inverter part number is required? The seller states it is compatible, but obviously they could be wrong.
May 21, 2009. 8:58 PMosurfc says:
Man your good. Well that fixed it. Not completely. I reconnected all the wires. It powered up fine. After an hour. The light went out again, back to square one. If I close the laptop and open it again the light sometimes is back on but then it goes out after 10 secs or 2 minutes. I'm wondering if it is the backlight?? I now have a new inverter installed. I don't think I should try to install a new backlight but sending it out is the same cost as a new LCD panel on ebay. Do you think it is the backlight??
May 21, 2009. 9:00 PMosurfc says:
Also, could there be a short in the wire (on and off with opening/closing)?
May 17, 2009. 5:02 PMosurfc says:
Thanks Vegas! I ordered the LCD yesterday and the inverter today! I hope I can send the LCD back... Now, what casino do you recommend on my next visit to LV?? Looking for some omaha and hold'em. HAHA!
Nov 25, 2008. 9:13 PMkikioncloud9 says:
OH MAN! U make it look so easy!! I dunno if im gonna be able to do it ! i just dont have the extra 200 bucks to take it in! Wish me luck.. lol
Oct 13, 2008. 7:25 AMf_m says:
Very helpful.
Apr 15, 2008. 9:54 AMcellobob says:
Hey Las Vegas thanks! I am so glad to have found this info, it has saved me time and money. So easy, never thought it would be.
Aug 5, 2008. 1:49 PMmrsgadget says:
I am absolutely SHOCKED at how easy this was!!! I had bookmarked this page several months ago, purchased the new LCD and let it sit in the closet. Today I decided to just go for it. I had taken the time to collect all the right tools, as well which made the job a WHOLE lot easier. The computer is updating as I type this. This saved me hundreds of dollars. Thanks, very well written instructions!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:LasVegas
