Step 3Obtain 54 Round or Raised Square Metal Tabs of 6 different raised shape designs
WARNING 1: The Designs must FEEL different from each other. Each shape needs to have a distinguishing characteristic to differentiate it by touch rather than sight. THIS IS IMPERATIVE.
WARNING 2: It is best to ensure that each of the 6 shapes is quadratically symetric* in design (i.e. turning the shape 90 degrees yeilds same design as before turned). This ensures that after mixing and solving... the cube looks complete (note that one of my shapes does not follow this rule).
Many who are new to Rubik's cubes are unaware of the fact that if you were to draw arrows on each square of the cube when you buy it, solving it to perfection is not as easy as some pieces will not be soundly placed (arrows in all same directions). See picture for understanding... you see the colors are all in place... but the cube is not truly solved. Unless you know how to solve a cube like this... you will want to ensure the designs on the tabs are symetric as I mentioned.
- - I am not sure if this is even a word, it just made sense in my juvenile vocabulary.
Something I don't know is whether it is possible to manipulate a cube such that a given center (or combination of centers) can be rotated relative to the edges and corners, while ending up with the same solid-color faces. This is your second point; it may in fact be impossible given the engineering of the joints.
As for the number of solved states, we can do the math here. The corners provide a reference frame -- because each one has three unique colors,
their positions relative to one another are fixed, so therefore there is only 1 solved state for them. With the corners fixed, each edge in turn can have only one position and orientation, and therefore there is also a single solved state.
That leaves only the four internal degrees of freedom for the six centers; the total number of such states would be 46 = 212 = 4,096.
Again, I don't know whether those states are reachable. If they are, then your discussion above about the meaning of "solved" is on point. If not, then the solution state is unique for any cube which is not disassembled and reassembled.
ROTATED CENTERS
Imagine a picture cube where all the pieces are permutated (in the right place) and all the cubies are correctly oriented (rotated) except the middles. It is IMPOSSIBLE to rotate a single face 90 degrees. If you rotate one center 90 degrees you ALWAYS rotate another center 90 degrees.
It is possible to have 5 centers correctly oriented and be missing the 6th. Here's how. Assume you have a perfectly solved cube and two faces, let's say Face#1 and Face#2. The following two steps can rotate a single face 180 degrees.
1. Rotate Face#1 clockwise 90 degrees and Face #2 clockwise 90 degrees simultaneously
2. Rotate Face#1 clockwise 90 degrees and Face #2 counter clockwise 90 degrees simultaneously
Notice that Face#1 has been rotated clockwise twice whereas Face#2 was rotated clockwise and then counter clockwise (leaving it in it's original position). On a side note, by "face" I mean "center"
I learned this while solving picture cubes, which are not very different from regular cubes. Just slightly different.
-Robin
