Introduction: DIY $1 PIC 12f675 JDM Programmer (Cheap and Easy)
Picture of DIY $1 PIC 12f675 JDM Programmer (Cheap and Easy)
Hi EveryBody i am Again Doing something. and it is with PIC's!
Almost Everybody do not want a Big Arduino in their projects or to control a rgb led with Arduino uno?
Enjoy Compressing your projects with PIC and Attiny too. but in this wwe will be making a PIC Programmer
To Program 12f675 PIC. Here i am not sure that it works for other 8 pin PIC too.but for sure it will work for PIC 12f675.
It is Really Cheap Programmer if you have a computer with JDM Port and has a 13v supply in it.
It is not really my Work but the Site was in Russian so i translated the project into English and it would great for persons like me who don't want to spend 100$ on a PIC Programmer and just want to tinker with Microcontrollers.
It Cost me only 1$ (Excluding PCB which i made at home)
Project can also be found at - Here
So, Let's Make it!
Step 1: Get the Parts
Picture of Get the Parts
List of Parts you Need:-
1. 8 Pin IC Base(1 pc.)
2. 470uf /25v Capacitor(1 pc.)
3. 10uf/25v Capacitor(1 pc.)
4. 0.1uf Ceramic Capacitor (104 Code)(1 pc.)
5. 78L05 5v Regulator(1 pc.)
6. 1N4148 Zener Diodes (1 pc.)
7. 5v6 Zener Diode (2 pc.)
8. 12v Zener Diode (1 pc.)
9. 10k Resistor (2 pc.)
10. 1k Resistor (1 pc.)
11. Green 3mm Led (1 pc.)
12. DB-9 Connector
(Images are Not Mine and they are for reference only)
Step 2: Schematic
Picture of Schematic
I Have Converted the Schematic From Russian to English and therefore For All Those who cannot understand Russian Like me, can See English ones. (It took me to 20 min in finding the correct russian words to convert it to english with google translate)
and another is the pinout to connect the PIC with labeling on other Schematic ;)
Step 3: Print Out the PCB
Picture of Print Out the PCB
Sprint ViewerI Made Toner Transfer and used HCL with Hydrogen Peroxide to Etch the PCB.
it worked great with glossy Photo paper with Laser Printer!
PCB Files can be Found Below.
PCB Files can Be Opened in Sprint Layout Viewer.
Download it from here - Sprint Viewer
Step 4: Drill and Solder the Components!
Picture of Drill and Solder the Components!
At last Drill the PCB and Solder the Components According to the Layout Given in Picture.
Step 5: And Now How to Program?
Picture of And Now How to Program?
Now Attach this to your Computer DB-9 Connector and Download IC-Prog and WinPic800 will work too.
Now it is all upon you to how to Program :D
My more PIC chips would be coming in 1-2 weeks and i will start making amazing projects out of them!
and Don't Forget to Select "JDM Programmer " option in which ever software you are using!
(Just Click on the name of Programmer to Download).
Any Questions ?.. Free to Ask :)
john parkerV (author)2017-10-11
will it work on pic12f629 chip?
mahdijoon (author)2015-02-22
i made it in RS232 socket without PCB similar USB flash
it work very good
but connect to back of my PC is difficult & i want connect with a shield connector to PC
it work ?
Ayush Sharma (author)mahdijoon2015-03-07
Sorry For Late. Reply But then you may get an USB to RS232 Conveter for it.
meglador (author)2014-11-15
hey Ayush, cool project,nicely done. I m from india. if you dont mind what's your age.
Ayush Sharma (author)meglador2014-11-15
You can see by clicking on my name :p
tcambrón (author)2014-11-09
very cool
Ayush Sharma (author)tcambrón2014-11-12
Thanks!
manumanu764 (author)2014-11-11
Just built it and it works like a charm! You can use this software too: http://picpgm.picprojects.net/download.html just make sure you choose JDM programmer from the options menu
Ayush Sharma (author)manumanu7642014-11-12
Nice to See! I will Start my PIC Projects soon.
And i forgot to mention that line :p
About This Instructable
12,559views
60favorites
License:
Bio: Just a Small Tinkerer ;)
More by Ayush Sharma:Pocket ESP8266 Weather Station [No ThingsSpeak] [Battery Powered]Make an Simple Motion Sensor Theft Alarm! (PIR) (DIY) How to Make ESP8266 Ultra Mini & Simple Relay Home Automation Board
Add instructable to:
