A ND filter is essentially a dark piece of glass that reduces the amount of light entering the lens. For this project, the ND filter will reduce the amount of light by 10 STOPS! Why would anyone want to reduce the amount of light entering the camera? Well, by reducing the amount of light, we can use a slower shutter speed. This will create motion blur (great for moving water). Another popular reason for using a ND filter is to use a larger aperture, creating thinner depth of field without over exposing. If you want to know more about ND filters, check out the Wikipedia article: http://en.wikipedia.org/wiki/Neutral_density_filter.
If you're ready, lets begin.
Things you will need:
- Welder's Glass/Lens Green Shade #10, <$10 on Amazon
- DSLR or camera with manual controls
- Lens or lens adapter that accepts threaded filters
- A spare UV filter. These are pretty cheap, sometimes free if you buy camera related items on sites such as Amazon
- Tripod
- Remote for your camera
- Lens cleaning supplies
- Black or dark electrical tape. Must be dark to prevent light leaks
- Time
- Working knowledge of long exposures
- Optional: Step down rings
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
It might be easier to use cokin adapters and tape the glass to that. It's flat around the edges, so the taping would probably be easier... I'll have to get another glass and try it!
Yes, the filters are bloody expensive. But, every time you put additional glass in front of your lens, you are degrading the image quality. The more expensive filters are designed to keep that degradation (if any) to an absolute minimum. Something tells me that a welders glass doesn't take that degradation into consideration.
For limited application, I could see your project being absolutely suitable. It's a good project, but with limited application.
your right that this welder's glass is not the best optically. However, this is instructables. People are interested in mods, alternatives and diy projects even if there is a store bought solution. im sure you can go around this site and just say "you can buy something that is better" to every other guide, but then youre kinda missing the point of this site.
Enjoy!
I suppose you could try it. But if that were the case, I don't think manufacturers of the lens filters would actually be selling any. The pro shooters would simply use your idea.
As for a range of lenses, commercial filters are stackable; a set consisting of ND2, ND4 and ND8 (<$10 from China) will give you 6 ND's all the way to ND64 (mind you anything beyond ND16 is fairly unlikely to find much use i{^_^}).
Having said that I love your picture of the deserted bridge. One of my favorite pictures is a late 1800's plate I rescued taken in the Melbourne Government library. The exposure time was so long that even the hour hand on the clock is a lost blur.
http://www.ebay.com.au/itm/52mm-Neutral-Density-ND4-Filter-52mm-lens-/250825426359?pt=Camera_Filters&hash=item3a665c45b7
Help a few malnourished Chinese kids instead of helping fat cat retailers ripoff a new BMW.
The whole square thing seems to beg for problems.
thank you!
Use one for the largest filter size you use ie 77mm and then use step-down rings to reduce the size for different filter sizes on your different lenses. The step down rings are very inexpensive, far less than sacrificing another filter. I get them for about $5 at a local camera store.
You can even mount a large step down ring to the glass in the first place. Either way, then your ND filter would be truly universal for all your lenses.
This is a great idea and one that I will soon try out. Thanks
Ideally, you should check against a known pattern and test each color swatch on it in software. I suspect the welding glass is pretty close but not perfect.
Shade 5
Shade 10
Shade 14
Any welder's supply place should have all three of those.
But, if you want a #10 ND... this is a fun way to DYI.
EXCELLENT-ibble!
I actually picked up one of those at Home Depot for $5, last year.
They were changing brands or something...
(I won't mention that it's just sitting in my tool box drawer, unused so far)
But, i wanted to ask about "Welder's Glass/Lens Green Shade #10" where can i buy it? any links maybe? because i've searched at amazon but i'm scared i've got a wrong items.
If youre not sure, you can go to a hardware store and check samples. Bring your filter with you to see if everything fits. This will be easier as you get to handle the actual glass piece. You can check it out in store then buy it online. ;)
If someone decides to try this and there is a welding supplier you will have more choices and possible less cost.
