DIY 1000 watt wind turbine by sspence
Featured
We built a 1000 watt wind turbine to help charge the battery bank that powers our offgrid home. It's a permanent magnet alternator, generating 3 phase ac, rectified to dc, and fed to a charge controller. The magnets spin with the wind, the coils are fixed, so no brushes or slip rings necessary.
Step 1: Build the magnet disks
We had 12" steel disks hydro cut. We cut a template for mounting the magnets. Then we mounted 12 grade n50 magnets around the outside edge. We then built a form, and poured the resin with hardner.
Step 2: Build the coil disk
We wound the nine individual coils, soldered them in a 3 phase wye configuration, and encased them in resin. We used 35 turns of 2 parallel strands of 14 gauge enameled (magnet) wire for 12 volts. Use 70 turns of single strand for 24 volts. # 3 phase diagram shown here shows 3 stator coils. each of those coils is actually 3 coils in series. coils 1,4, and 7 are series together, 2,5, and 8 are series together, and 3,6, and 9 are series together.
more details, see the following page 15 for the series star, 1-y diagram.
http://www3.telus.net/faheydumas/Wind_Turbine/Forum/AXIAL_FLUX_HowItWorks.pdf
Step 3: Build the bearing assembly
Two Harley Davidson wheel bearings are inserted into the pipe, with a smaller pipe locked between them to keep them in place.
Step 4: Construct the blades
The blades are 2" x 6" pine, cut at 10 degrees on a table saw, and sanded into a rough airfoil. Not perfect, but close enough.
More can be found at
http://tech.groups.yahoo.com/group/axialflux/
http://www.green-trust.org
http://youtube.com/watch?v=o9EEHFKEckM
Step 5: Further Reading
1-40 of 1408Next »
Macattacku says: May 11, 2013. 5:53 PM
If u want to generate over 30% more power at 12volts then change the windings to 24 volts and the change it to a delta 3 phase formation instead of star formation. This will bring it back to 12volts. At higher speeds it is more efficient therefore generating more power.
hamid manzoor says: Apr 18, 2013. 4:49 AM
What is power of your individual magnet??
in Tesla??
sspence (author) says: Apr 18, 2013. 6:38 AM
The grade, or "N rating" of the magnet refers to the Maximum Energy Product of the material that the magnet is made from. It refers to the maximum strength that the material can be magnetized to. The grade of neodymium magnets is generally measured in units millions of Gauss Oersted (MGOe). A magnet of grade N42 has a Maximum Energy Product of 42 MGOe. Generally speaking, the higher the grade, the stronger the magnet.
Tesla's don't convert to MGOe. Apples to oranges.
http://en.wikipedia.org/wiki/Oersted
http://en.wikipedia.org/wiki/Tesla_(unit)
rlange3 says: Feb 23, 2013. 1:47 PM
nevermind, just realized i need a slip ring, and yours is stationary, so you don't need one, you even stated that. My bad.
sspence (author) says: Feb 23, 2013. 1:57 PM
Ours is not stationary, we just manually unwind the cable on occasion.
rlange3 says: Feb 22, 2013. 11:03 PM
how do you keep the wires that go down the pipe from becoming twisted as the tail makes the generator spin?
sspence (author) says: Feb 23, 2013. 8:14 AM
the tail rarely goes round and round, more back and forth. If you see the wires getting twisted, just untwist them manually. Otherwise, you need slip rings, which was beyond the diy focus of this project.
otuaga says: Feb 11, 2013. 4:18 PM
thanks..
otuaga says: Feb 11, 2013. 7:46 AM
It is part of my question, what voltage should I make the battery bank in order to both use the 48V turbine and run the 144V motor?
sspence (author) says: Feb 11, 2013. 3:41 PM
All 3 have to match. Unless you can get a 120vac motor, then that can run off a 48v inverter.
otuaga says: Feb 9, 2013. 4:24 PM
motor voltage = 144V
battery bank = 48V
do you mean that I can wire the wind turbine to the battery bank directly?
sspence (author) says: Feb 10, 2013. 4:39 PM
Yes, if it's a 48 volt wind turbine. You put a dump load controller on the battery bank that enables a resistive load when the batteries are fully charged. How do you expect to run a 144v motor on a 48 volt battery bank?
otuaga says: Feb 9, 2013. 9:15 AM
Maybe you can help me with my situation. I want to install a 1kw wind turbine solely for the purpose of running a 90hp DC motor, my main problem is that they both
each require different types of controllers. How can I wire the wind turbine through its controller to charge the batteries and at the same time wire the motor through its controller to draw power from the same battery bank?
sspence (author) says: Feb 9, 2013. 2:28 PM
what voltage is your motor? what voltage is your battery bank? the wind turbines does not have a controller.
acarroll3 says: Jan 30, 2013. 4:27 PM
How did the performance of the turbine that you built compare to the expected performance?
sspence (author) says: Jan 31, 2013. 4:07 AM
It met expectations. We knew it would, since there are calculations that will determine what output will be at specific wind speeds. See
http://green-trust.org/windpowercalc/
acarroll3 says: Jan 29, 2013. 2:25 PM
Hi Sspence,
Did you do any sort of wind potential audit before beginning to design and build this turbine? If so could you point me in the direction of the software or other method that you used?
sspence (author) says: Jan 29, 2013. 4:37 PM
I installed a cheap AIR 303 wind turbine (<$400) and ran that for several years, logging the wind data.
rborba1 says: Jan 9, 2013. 8:02 AM
We’ve come a long way since the early days of electric power but the principle has remained exactly the same, all you have to do is spin a wheel.
The spinning wheel is the heart of every power system in the planet.
With that in mind, I thought of something simple.
Let’s say we drop 64.2lbs from 100 feet high with a line attached to a spin wheel, depending on the set up that wheel would spin many times.
Now comes the simple idea, first how do we lift those 64.2lbs back up there? A little bit of air.
Just one cubic foot of air can lift up to 64.2lbs of dead weight in fresh water.
Now rain or shine, day and night we can produce electricity.
My name is Richard Borba, I’m looking for someone who can help me turn this idea into reality, I’m sure it’s a really bright idea to produce electricity without causing any harm to ourselves and our planet.
Email me at mrborba@gmx.com
naught101 says: Jan 27, 2013. 2:07 PM
Every power system on the planet except for those driven by photovoltaics, piezoelectricity, pyroelectricity, etc.
sspence (author) says: Jan 9, 2013. 9:01 AM
You might think that, but you need to do a little research.
Palomarbob says: Jan 26, 2013. 4:43 AM
A small 2 blade 16" ~ 17" diameter hxwt will out produce any vxwt by 5x
Use rc motor from a hobby store 20v ~ 30v; 1a ~ 2a; 2000rpm ~ 3000rpm
18ah battery do not charge above 11 watts with diode or diodes
1" ~ 2" tip chord @ 4 ~ 5 deg ( 2" ~ 3" chord at 50% radius @ 11 ~ 12 deg)
airfoil goe188 ( flat side faces wind ) very easy to make
sspence (author) says: Jan 26, 2013. 5:44 PM
1. This is not a VAWT, it is a HAWT.
2. This unit spins at 650 rpm
3. you aren't going to get 1000 watts with a rc motor
laiskasmariui says: Nov 30, 2012. 7:40 AM
Hi, How did you determine which wire gauge to use?
1000W / 12V = 83.3A
from any of the ampacity tables i could find online 83 Amps would need arround AWG 4 for enclosed wire and AWG 7 for open air application. Am I missing something? Please explain.
sspence (author) says: Nov 30, 2012. 7:47 AM
Ampacity tables do not take into affect length of the wire. Each coil , plus each phase carries 1/3 of the current. 35 turns of 2-in-hand 14awg equals 11awg. Each turn is about 6" of wire, so it's about 17' of wire. This equates to a 8% voltage drop at maximum power. If you want to drop to 3%, you could try dual 9awg, but that would be hard to wrap.
laiskasmariui says: Nov 30, 2012. 2:24 PM
Thanks for the response :) I didn't realize that the three phases share the current.
sanjay_lim says: Jan 12, 2013. 8:49 PM
I agree with laiskasmariui , don't think more than 200watts at 12 volt is possible from the above setup is produced.
sspence (author) says: Jan 13, 2013. 6:52 AM
You think wrong.
rborba1 says: Jan 9, 2013. 9:14 AM
I did it and I patented as well, just don't have equipment to get it done
sspence (author) says: Jan 9, 2013. 11:40 AM
You never will.
Capo118 says: Dec 7, 2012. 11:42 AM
Is this enough wattage for a home? If not what would be a good average wattage amount
sspence (author) says: Dec 7, 2012. 12:19 PM
Depends on the home, and how much wind you get. with 6 hours of good wind, this unit might produce 4.8 kWh's daily. The typical home uses 30 kWh or so. My off grid home used 10 kWh's daily. I produced over 8 kWh's with solar.
NickChaney says: Nov 25, 2012. 4:23 AM
Hey, very interesting stuff. What was the total cost of the whole thing?
sspence (author) says: Nov 25, 2012. 4:43 AM
Somewhere in the neighborhood of $1500 or so in today's dollars.
TheStudio7 says: Nov 18, 2012. 10:23 PM
This is one awesome instructable. THANK YOU.
twighahn says: Oct 15, 2012. 3:46 PM
i need the diagram dummied down
sspence (author) says: Oct 15, 2012. 5:15 PM
Here is a great explanation of the coil wiring - http://www.instructables.com/id/WIRING-THE-COILS-IN-3-PHASES-AXIAL-FLUX-GENERATORS/
Also read http://www.windenergy.nl/website/files/artikelen/AXIAL_FLUX_HowItWorks.pdf for more info.
abrits says: Oct 12, 2012. 3:06 AM
Why not just use a fisher and paykel smart-drive motor.
sspence (author) says: Oct 12, 2012. 6:05 AM
Because this is a DIY axial flux instructable. We teach people to make their own alternators, not have to buy someone else's design.
msexton2 says: Oct 8, 2012. 4:52 PM
what dimensions are the magnets you used?
x
1-40 of 1408Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
