3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY 1000 watt wind turbine
Step 3Build the bearing assembly
Two Harley Davidson wheel bearings are inserted into the pipe, with a smaller pipe locked between them to keep them in place.
7 comments
Feb 12, 2011. 3:27 PMdwkipling says:
will the pipes rust?
Sep 24, 2008. 3:34 AMvimal roy says:
there is no detailed explanation about construction
Apr 4, 2010. 3:55 PMSilence says:
Its quite simple by the look of it. Theres 2 tubes, one fits inside the other, the largest being big enough to house the bearing set with the smaller acting as a simple spacer to keep the bearing sets from falling in further than you want.
Mar 14, 2009. 7:10 AMrwlakin says:
I found a simple bearing mount is to use a small trailer 4 bold hub. Use the axel part of the hub for you prop mount and the other end for your generator. The hub rim part as your mount. The trailer hub is $20 bucks or less with your bearings, spindle, and hub. Roger
Jun 5, 2006. 10:44 AMBCohen says:
people looking for more should checkout: www.otherpower.com. There is a TON of information on doing stuff like this.
Jun 4, 2006. 5:22 AMgniman says:
pictures for steps 3, 4 and 5 don't show up
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
185
Author:sspence(Arduinotronics)
Professionally, I'm an IT Engineer (Executive Level) and Electronics Tech. I'm a Amateur Radio Operator (KK4HFJ). I lived off grid, with Solar (PV), Wind, and veggie oil fueled diesel generator power ...
more »
