DIY 2 Cycle Steam Conversion
 by tngun
video DIY 2 Cycle Steam Conversion
This video shows how to turn a discarded 2 cycle weed eater into a simple steam engine.  In the video I am using an air compressor, but later I created a very primitive boiler from a pressure canner and a safety valve.
While this is a very easy project, it took me a long time to figure out a relatively safe way to produce steam.  If your going to attempt a project like this, please be aware that a steam explosion will most likely kill or main you, so use a certified boiler.
heathbar64 says: Aug 2, 2012. 4:18 PM
very cool project. I appreciate all the details. a couple thoughts to contribute. Most spark plugs are 14mm, so you could use a 14mm threading die to thread the end of your nipple. or rethread your plug hole with a pipe tap. another option is to break the porcelain from an old spark plug and braze it onto your pipe nipple.
for the flywheel, why not make a steel band around the existing flywheel and pour molten lead into it to fill the vanes.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
