DIY | 20 Watt Powerful Amplifier Using TDA2005 - Easy to Make
1,147
32
Posted
Introduction: DIY | 20 Watt Powerful Amplifier Using TDA2005 - Easy to Make
20 Watt Powerful Amplifier Using TDA2005 - this is one of the easy amplifier anyone can build
Step 1: Making Video
You can watch the making of the video by the clicking the video linked in this step or continue reading to make your own 20 watt amplifier
You Can Subscribe To My YouTube Channel By Clicking HERE
Step 2: Components Required
1. TDA2005 - Buying Link
2 Heat Sink - Buying Link - USA or Buying Link - IND
3. 1000uF/25 volt
4. 220uF /25 volt - 2
5. 2.2uF /25 volt
6. 10uF /16volt or 10uF /25 volt
7. 0.1uF Ceramic capacitor - 4
8. 10 ohm resistor - 2
9. 1 ohm resistor - 2
10. 1.5k ohm resistor
11. 1k resistor
12. 3.5 mm Male Jack with cable
13. 3.5 mm Female jack
14. Any Speakers for testing
15. Heat Sink Compound
16. PCB board
17. Wire
18. Battery & Battery cap
19. Soldering rod, soldering wire & soldering paste
20. Wire stripper
Step 3: Circuit Diagram
1st Image - Circuit Diagram
2nd Image - In this image i have shown how to add a volume control. The volume control part is not included in the circuit diagram and also in my construction. This part can be skipped. Only add this if you want a volume control in your amplifier.
Step 4: Construction :
Mount all the components on PCB board and make connection according to the circuit diagram .
Few Tips :
1st Image - Connect the TDA2005 and before connecting the other components make sure to leave some place for the heat sink. My suggestion - Place the heat sink & mark the area.
Make sure you connect all the nodes properly
8th, 9th & 10th Image - I suggest to add heat sink compound on the heat sink and then attach the heat sink to the TDA2005 with a screw. Heat sink compound helps to transfer the heat from the TDA2005 to the heat sink at fast rate. This also have a additional help of transferring the heat from the plastic part of the TDA2005 to the heat sink
Note : I recommend, adding a small 5 volt computer cooling fan if your running the amplifier for the long time on the go.
12th Image - I have change few components while construction my PCB board which is explained in this image. You need not change the components. The reason for me to change this is i was short of components in my stock.
Step 5: Finished Images
3rd Images - this image gives you brief technical aspects of the amplifier.
Note : For better results i recommend you to supplying 12 volt as input voltage
To watch the amplifier performance please CLICK HERE
Testing begins @ 3:20th minute of the video
If you interested in making this product you can please use my affiliate buying links to buy the components
Do you want to support my videos?
If Yes, Please browse and buy things from my Amazon Store. This way I get a small commission which will help me produce more videos. Please use the link to visit my store : http://goo.gl/gKjns4
You can also contribute to me on Patreon using the link : http://goo.gl/gKjns4
Amazon USA:
TDA2005 - http://amzn.to/2ajeQAN
Heat Sink - http://amzn.to/2ajfRsI
Heat Sink Compound - http://amzn.to/2abd9zW
Soldering Kit : http://amzn.to/29RyXjJ
Wires - http://amzn.to/29Y1kwt
PCB Board - http://amzn.to/2abRXw7
Insulation Tape - http://amzn.to/29YNZax
Wire Stripper & Cutter - http://amzn.to/29RBsm8
Resistors, Capacitors & Others Things : http://amzn.to/2a2CzU8
3.5 mm Jack - http://amzn.to/29Y2Rmb
Amazon India:
Heat Sink - http://amzn.to/2agGgDF
Heat Sink Compound - http://amzn.to/2a6FHim
Capacitors, Resistors & Other items - http://amzn.to/29GbUwT
Soldering Kit - http://amzn.to/29P00wv
Wires - http://amzn.to/29GdPBl
PCB Board - http://amzn.to/29Ged2O
Scissor - http://amzn.to/29P2ECE
3.5 mm Jack - http://amzn.to/2a5dSEL
Wire Stripper & Cutter - http://amzn.to/2a0wBD8
Please Subscribe To My YouTube Channel by CLICKING HERE
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
