loading
loading
Picture of DIY 3D Controller
Make a 3D interface using an six resistors, aluminum foil, and an Arduino. Take that, Wii.
Update: a much more thorough explanation of this project is available from Make Magazine. It might be easier to follow their instructions, and I think their code is more up to date.
The basic goal here was to make a 3D hand-position sensing system that most people can build, while still preserving some semblance of functionality. To get an idea of possible applications, check out the demo video. If you think you can build one that is simpler and equally accurate, or slightly more complex and more accurate, share in the comments!
DIY 3D Interface: Tic Tac Toe from Kyle McDonald on Vimeo.
Step 1: Materials
Picture of Materials
Tools
Materials
  • (3) 270k resistors
  • (3) 10k resistors
  • Solder
  • Wire
  • Aluminum foil
  • Cardboard
Optional:
  • Tape (e.g.: scotch)
  • Shielded wire (e.g.: coaxial cable, ~3')
  • (3) alligator clips
  • 3-pin header
  • Zip-tie
  • Shrink wrap tubing or hot glue
Step 2: Make the Plates
Picture of Make the Plates
This sensor will work using simple RC circuits, with each circuit sensing distance in one dimension. I found that the easiest way to arrange three capacitive plates for this purpose is in the corner of a cube. I cut the corner of a cardboard box into an 8.5" cube, and then cut some aluminum foil to fit as slightly smaller squares. Tape on the corners keeps them in place.
Don't tape down the entire perimeter, we'll need it later for attaching the alligator clips.
Step 3: Make the Connectors
Picture of Make the Connectors
To connect the Arduino to the plates we need some shielded wire. If the wire isn't shielded, the wires themselves act more obviously as part of the capacitor. Also, I've found that alligator clips make it really easy to connect things to aluminum -- but there are probably plenty of other ways, too.
  • Cut three equal lengths of shielded cable. I chose about 12". The shorter the better. Coaxial cable works, but the lighter/more flexible the better.
  • Strip the last half inch or so to reveal the shielding, and the last quarter inch to reveal the wire.
  • Twist the alligator clips to the wires onto the wires and solder them together.
  • Add some heat shrink tubing or hot glue to keep things together.
1-40 of 262Next »
iltabhai8 days ago
This project only works on the processing 1.5.1.
WaleedR18 days ago
ArrayIndexOutOfBoundsException: 2 is the error and the TicTacToe 3d is not responding.
WaleedR19 days ago
hey when i upload the code in processing it says can not find anything named "sensors"
Has anyone been able to figure out the problem where the grid shows with the ball in the top back cube? It says its calibrating but nothing .
Csaub0014 months ago
When I run TicTacToe on processing I get a white screen... Processing highlights this line
serial = new Serial(this, Serial.list()[serialPort], 115200);
any ideas?
try to write "int serialPort = 0"
smartmiltoys3 months ago
Nothing will EVER be better than the keyboard and mouse. Nobody wants to
hold their arms out for minutes at a time. Nobody who actually does
anything productive on their computer, that is.
凱文鄭 made it!3 months ago
Hey guys,
I used this awesome system making something fun which is a abduction game of sucking people by UFO. You can move your hand to control the UFO position.
Here is project's github. Enjoy it!:
https://github.com/kevinphys/3Dtracking-AbductionG...
phammer2 years ago
Hi I have got the thing up and running with the problem that when running the processor the gray box appears instead of the cubes and when I move my hand the grey box moves with my hand instead. Any solution for this?
It's been quite a long time since you built this, propably. But did you figuered it out? I still got the same "problem". Quite nice to move objects with this controller. But i want to fully finish this project and hammer the "I Made it!". Thanks
returner11 months ago
guys i m really new to this stuff and i want to learn on how to do this... i have no idea why i cant run this program??? my tic tac toe prog shows me that its not responding every time.. help please?!
thanks in advance.
returner returner11 months ago
i changed my serial port to 0, "int serialPort =0;" , and sensor to sen and i still cant get it to run. help anyone?
imaginei returner4 months ago
did u ever get this to work? i have the same problem.
firobug5 months ago
could you improve this size by additional pannels... you said something about the largest you being able to do was only a foot or so and i think that may be just because of the limits of the capacsitance of the aluminum if we add say another set of say 9 panels could we make this a 2 foot cube and better yet could it be extended by using strips i could glue to my walls and ceiling to give me a full 3d cube to interact in...maybe add streamers to get me a 3d display with projectors.....
firobug5 months ago
I cant seem to get it to work :(
The sketch runs and in Processor i can see that it says "defining boundaries" whenever I left mouse click
But nothing after that!
HELPPPPP
(I am using Make:'s code btw)
davidbarcomb5 months ago
Awesome project! I love it
JenniferG27 months ago
I followed the Make instructions that used 220K resistors and if I watch the Serial Monitor, all I get are 0 0 0. Is anyone else having this problem? I'm not sure if the resistors are the problem or something else.
i'm still unsure what this is, can some one explain please?
DangerousTim9 months ago
why don't you use the capsense library? It's quite good, and you'll need only one resistor per foil...
anandsd11 months ago
sir can u pls send me the tit tac toe code to this email: anandchidambaram2007@yahoo.co.in
i have made the senser cube and finished the connection but i dont have the program.
XYZAidan12 months ago
When I run the processing program, the window is brought up. It has the cubes and the sphere, but the sphere is in the upper back cube, and my hand doesn't affect it, even if I calibrate. Anyone have a solution?
rgreen10 XYZAidan11 months ago
Did you ever get it figured out? I am having the same problem.
Ramzeez1001 year ago
Hi, I realize this comment may be a bit late, but I'm a bit new to Arduino and I was trying to get this to work. I'm using an Arduino Uno, which Make Magazine used, and I fixed the processing code and got everything uploaded and running. When I run the TicTacToe3D program from processing I am able to see the grey cubes and the red ball, but when I place my hand in while left click holding the window, nothing happens except for the program saying "defining boundaries". Any help?
look to the video
rgreen10 mwezel11 months ago
If their problem is the same as mine, the video's instructions do not work. The "defining boundaries" message shows up, yet the ball never moves.
slickman841 year ago
Then I open Processing program and then I open the TicTacToe3D its saying "cannot find anything named sensors.
Change "sensors" to "sen".
kovacp11 year ago
The 'code is available here' link above is broken,
Is the code available anywhere and tare there instructions for compiling it?
Thank you
kovacp11 year ago
What is the application code written in?
I use visual studio - has anyone made an app for that.
Thank you
akumama1 year ago
Hey Kyle, this is amazing, I first saw it on MAKE but have been meddling with it myself for some time now. I have got it working to an extent, but when I run it in processing, once I've clicked to get it to follow my hand, the ball just floats around one area. Do you know why this might be?
fanak2 years ago
An interesting application would be to make this as a controller for a mechanical arm
vvieira2 fanak1 year ago
In progress...
But the sensors still not working with me :/
theamateur1 year ago
probably the coolest instructable i have seen to this day.
rami20131 year ago
Hi all,
I’m testing this with just one panel and using the test program (_3DInterface)
if I’m shorting pin 8+9+10 it’s working but reports three outputs,I would like just one output and that pins 9 and 10 (on the arduino) will be disconnected.
tried changing line for(inti=8;i<11;i++) pinmode(i,input), to for(inti=8;i<9;i++) pinmode(i,input)
but it didn't work, each time i remove the short line between pins 8+9+10 the output stops.
Please advise
rami
Hi all,
Please advise
rami
AVNERD1991 year ago
Is there any way i could make a bunch of small ones and put them in a pattern to make a touchless keyboard?
fmmehr1 year ago
hey thanks for your great project the only thing is i can't make the tictactoe3d working on processing app it gives me errors and it can't export the application can you please help me or can u send me the ready made tt3d app to instal or right code thank you
my email is farbod_mjl@yahoo.com
mindlelle2 years ago
Hi, I have done everything and I see TicTacToe3D screen with boxes and orange ball. but the problem is that the ball doesn't move at all. It doesn't react. Any advice? What could be a problem? Help me~
allready tried to calibrate it? and did you use shielded wire, or else your body may act as a capacator.
Hope it helps!
1-40 of 262Next »
