3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY 3D Controller
Step 3Make the Connectors
Make the Connectors
To connect the Arduino to the plates we need some shielded wire. If the wire isn't shielded, the wires themselves act more obviously as part of the capacitor. Also, I've found that alligator clips make it really easy to connect things to aluminum -- but there are probably plenty of other ways, too.
  • Cut three equal lengths of shielded cable. I chose about 12". The shorter the better. Coaxial cable works, but the lighter/more flexible the better.
  • Strip the last half inch or so to reveal the shielding, and the last quarter inch to reveal the wire.
  • Twist the alligator clips to the wires onto the wires and solder them together.
  • Add some heat shrink tubing or hot glue to keep things together.
6 comments
May 14, 2012. 2:31 PMArduino Guy says:
My sensor is not sensing my hand if it is farther than 3 cm away form any plate... can this be the result of using unshielded cable? or is it something else.
My readings are around 3500 an all plates and they rise if my hand is within 3 cm.
May 21, 2012. 2:31 PMArduino Guy says:
Well.. My arduino has a battery pack and a xbee... so thats the problem Ill try connecting it to ground, what a stupid mistake. I will let you know my results.
May 14, 2012. 2:43 PMArduino Guy says:
Also I forgot to add, my wires are ~5-10 cm, the third one longer.
Aug 24, 2009. 11:57 AMDemonSpawn says:
Why does it have to be sheilded or coaxial cable? why not just some single core wire?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:kylemcdonald
